Results 41 to 49 of 49
May 15th, 2009 06:37 AM #41
cjtjamandra'
i enjoyed educating the public about the cooling system principles. this thread is what i intended to be so as to reduce exhaust emissions and produce better fuel economy. so far, some people are thinking twice. the ones who have the ability to think at least. the others are incapable of thinking, just do what others do when making mistakes. monkey see monkey do. monkey no think that's why. some people are born stupid, some practice it. let's face it, not everybody is smart enough.
jick
certified auto
guam
May 15th, 2009 07:23 AM #42
peepz.
ganito set up ko sa trooper.
isang OEM na aux fan na may thermostat and yung isa ang naka sabay pag on ng aircon.
may cons ba to?
May 15th, 2009 04:32 PM #43
s_quilicot
there must have been confusion between fan thermoswitch and coolant thermostat. the switch controls the relay to turn the radiator fan on. the thermostat is closed until the preset temperature has been reached and starts to open, for toyotas and most asian cars they start to open at 86 degrees celsius. the thermoswitch kicks on when the coolant has heached 140 degrees fahrenheit. so, the thermostat opens before the radiator fan kicks on unless the system recognizes a request for airconditioning and that the a/c or the climate control is in working order
jick
guam community college
May 16th, 2009 05:52 AM #45
s_quilicot
the logic behind the condenser fan/ radiator fan operation is as follows for most asian cars:
engine cold/ no a/c-----------both fans OFF
engine hot/ no a/c------------radiator fan ON full speed
engine cold/ a/c on-----------both fans ON half speed
engine hot/ a/c on------------both fans ON full speed.
if you want to run this logic, get a toyota fan wiring diagram and have a qualified electrician install it for you.
jick
certified auto
guam
May 16th, 2009 06:44 AM #46
May 16th, 2009 08:13 AM #47
s_quilicot,
use the thermoswitch controlled fan as a push fan for the condenser. the radiator fan is viscous coupling fan. i have installed one on the same concept for a toyota previa, that when i converted from R12 freon system to R134 system, the existing viscous coupling fan was inadequate to cool both the condenser and the radiator. the electric cooling fan was running parallel to the a/c compressor clutch but is run on a separate relay.
jick
certified auto
guam
- Nov 2008
- 5
May 17th, 2009 10:22 AM #48Mina-san,
Pardon me for my stupid question but I Just wanna ask does it mean that when the thermostat gets open, it will remain open while the engine is on or will it close if engine temp gets low (say continuous downhill driving)?
May 17th, 2009 02:54 PM #49
newbie,
an automobile engine is subjected to an array of variables; engine rpm, engine load, vehicle speed, ambient temperature, altitude and mechanical condition. together with these variables, the engine temperature also changes. regardless of these conditions, the burn time, btu/pound of fuel, and the conditions inside the combustion chambers should remain the same by controlling the temperature of the engine block. this is where the thermostat comes into play. it regulates the temperature to a narrow band to put the combustion chamber to ideal conditions thereby reducing emissions and optimizing power output. your thermostat has a threshold temperature degned to it. it us durin this time when the thermostat begins to open and remain open until the temperature is at threshold or below. it also varies in the amount of opening in proportion to the engine cooling requirements. this band of regulated temperature is like the comfortable temperature of around 20 degrees fahrenheit lower than our bodies. this is the similar concept. to control the conditions so as to obtain the desired results
jick
a.s.e. certified master automobile technician
a.s.e. certified master heavy duty truck technician
international automobile technicians' network
my 19 yr old car .. as in naka 3M .. walang palitan.. maganda sa old 3M ng car namin as in hindi...
