Results 1 to 9 of 9
- Aug 2009
- 3
August 11th, 2009 02:46 PM #1Hi,
Tanong ko lang po kung alam ninyo kung ano rason kung bakit di umiilaw yung "D4" habang nasa "D4" yung gear. pero lahat nung ibang gear naman meron. With regards naman sa hatak and shifting,wala naman problema. Is it just a loose connection or busted bulb? need ur insights po and suggestion regarding this.. btw my car is a 2000 accord. Salamat po...
August 11th, 2009 02:51 PM #2
August 11th, 2009 07:09 PM #3
Yep, most likely just a burned-out LED. You can leave it as it is or have it replaced - either way it's relatively painless.
August 11th, 2009 09:04 PM #4
The bulb is busted, you have to remove the panel at the speedometer to have it replaced, have it brought to a reputable shop for replacement.
- May 2007
- 104
August 12th, 2009 01:46 AM #5Saan pong D4 light ang busted? Is it in the gauge or ilaw sa kambiyo mismo? kung sa gauge, remove the gauge and palitan mo lang bulbs, if your unlucky like mine, mhrap maghanap ng rice bulb na sobrang liit, that's why pnagpalit palit ko na lang ilaw ng gears ko. d4 ma ilaw d3 and d2 wala. pero it doesnt affect performance at all. kung may ilaw naman yng sa kambyo mo all good na yan
- Nov 2008
- 2
August 12th, 2009 07:42 AM #6yung sa akin ganon din sa 1st gen crv. pinapagpag ko yung instrument panel umilaw na loose connection siguro.
- Aug 2009
- 3
August 12th, 2009 10:00 AM #7mga sir maraming salamat po sa mga insights at reply nyo..bumalik nanaman yung ilaw ng D4 ko ngyon.. actualy it already happened twice na.. yung una was mga 2 weeks ago, nawala tpos mga 3-4 days bumalik ilaw, tpos nung saturday nawala ulit tpos bumalik nanaman sya ngayon..probably its just a loose connection lang nga mga sir. I'll just have it checked.. Salamat po ulit..
- May 2007
- 104
August 13th, 2009 03:47 AM #8
- Aug 2009
- 3
Babala! Sarado at Ginagawa mga south bound flyovers along c5. Medyo mabagal Ang daloy kanina Ng...
Traffic!
