Results 1 to 8 of 8
September 16th, 2010 07:48 PM #1
need help po..
Light sa dash po ng Handbreak ayaw mag off/ mawala kahit hindi na nakaengage ang hand break.. pero after few minutes (2 - 5mins.)mawawala na while driving..
then hanbreak ko ulit after driving naka stop okay naman na wala na yong problem
and ngayon naman po ang problem nawala naman ang light totally kahit naka handbreak or hindi..
TIY
GS
September 16th, 2010 07:52 PM #2
try mong check yung switch sa mismong handbrake baka maluwag ito. or yung check din ang wiring connection ng switch na ito
- Jan 2008
- 4,726
September 16th, 2010 07:59 PM #3possible pundi na yung light bulb sa dash.. or sira ang switch ng hand break mo..pero check mo agad yung level ng brake fluid pag low level na
September 16th, 2010 08:03 PM #4
yes tama si emj21 pwede rin brake fluid mo mababa na, tignan mo na agad then refill mo na lang, baka kaya naka continous light ito warning na pa ubos na ang fluid mo.
September 16th, 2010 09:47 PM #5
i would probably check the brake fluid reservoir first. wala nang laman yun.
check the clutch reservoir na din while you at it.
- Jun 2010
- 258
September 17th, 2010 06:02 AM #6kung wala problema bro sa fluids... tama sila check the swith at the wiring baka putol, nagshort o maluwag yan lang yan...or kung pundido na nga yun dash bulbs.
September 19th, 2010 04:12 PM #7
I just checked the breakfluid.. nasa normal level parin and nde nagbabawas.. siguro nga sa wiring ang problema or sa bulb na..
another question sir.. iilaw ba talaga yong handbreak light pag low level na breakfluid or empty?.. TIY
September 19th, 2010 04:14 PM #8
I just checked the breakfluid.. nasa normal level parin and hindi nagbabawas.. siguro nga sa wiring ang problema or sa bulb na..
sino po may alam na reliable shop sa banawe para magawa na to...
Latest mileage:
