Results 1 to 6 of 6
- Jun 2009
- 19
June 25th, 2009 04:20 AM #1mga sir ask ko lang po help nyo regarding sa ESI 95 ko. Last time nag CEL (Check engine light) ako then ayaw na umistart ng engine ko, rumerendondo pero hidi dumidiretso.. Bago pa man to mangyari, nagbabawas na ko ng tubig at medyo nagiingay na yung makina ko. Sinubukan ko icheck yung sa MAP sensor, normal naman ang nilalabas na kuryente at wala namang codes na nilalabas, pag jinajumper ko yung service connector. Sinubukan ko icheck yung main relay at nung isalpak ko ulit sya, naging normal na yung pag start nya ulit pero constant ng naka ilaw yung CEL ko pero wala namang codes na binibigay pag jinajumper ko..
ano sa tingin nyo mga sir?
- Jul 2008
- 33
June 29th, 2009 05:02 PM #2try to change your main relay,it happened to me,i just change it and solve the problem
- Jun 2009
- 19
June 30th, 2009 04:10 AM #3Thank you Sir!
Try ko palitan main relay. I'll keep you posted kung may pagbabago.
June 30th, 2009 10:25 AM #4
have you checked the timings and the valve settings (gaps)?
baka masyadong tukod?
- Jul 2008
- 33
- Jun 2009
- 19
August 19th, 2009 12:25 AM #6Update lang po mga Sir!
Nakapagpalit na po ako ng water pump, timing belt, tensioner at mga seals, ok na po yung pagbabawas ng tubig. Nagpalit na rin po ako ng main relay, nawala na rin po yung CEL at umiistart na ng maayos, kaso nung isang araw parang tinopak at medyo matagal mawala yung CEL, nung in on-off ko naging maayos nanaman uli... Ipatawas ko na po kaya kotse ko... hehehe
Maraming Salamat!
normally, i would feel for the e-bike and e-trike users, as "these are probably all they can...
E-bike / E-trike ban details released by MMDA
