Results 11 to 19 of 19
October 19th, 2009 03:07 AM #11
be sure of mechanics your getting to..dapat yung trusted na mechanic..mas better if my kilala ka or shop,because your girl baka tagain ka lang sa price,but before it,pa check mu muna,try a 2nd opinion from another mechanic,pareho yung sinasabi nila na cause ng prob din you should go for it..
- Oct 2009
- 25
October 19th, 2009 08:07 PM #12
- Sep 2009
- 46
October 19th, 2009 08:28 PM #14-most probably head gasket, check if may back pressure na by opening the radiator cap and malakas ang lumalabas na tubig sa radiator.
- Oct 2009
- 25
October 19th, 2009 09:46 PM #15
October 20th, 2009 02:43 PM #16
had the same problem for quite some time 'til i decided to change my radiator just last month.
na-inis na ako kasi ilang overhaul ng radiator tapos upgrade rating ng rad cap at no apparent leaks - sa wakas na-solve din ang problema
best is pa-check and seek for a second opinion sa mga reputable shops. saan po ba ang area niyo para ma-tulongan kayo sa pag-hanap ng shop ng fellow tsikoteers natin?
- Oct 2009
- 25
October 20th, 2009 09:58 PM #17
- Oct 2009
- 1
October 31st, 2009 08:13 AM #18
- Sep 2009
- 12
November 1st, 2009 05:21 PM #19Ok po...ito ang way para malaman mo kung cylinder head gasket nga ang problema. Di po ako expert pero based on my honda vtec '99 experience nung nauubos din ang water reserve ko, yan ang ginawa ng mechanic ko.
On cold engine (para safe at hindi mainit ang radiator), maybe before you hit the road in the morning. Open the rad cap then start the engine. Pag bumulwak o sumurit ang tubig ng radiator from radiator mouth, for sure cylinder head gasket yan or there's a leak somewhere in your engine. It needs to be replaced at sana lang hindi pa warp yung cylinder head. Do it at once at baka abutin ka pa ng overheat lalong malaki gastos.
Hope i got it right.
