Results 11 to 18 of 18
- May 2005
- 277
June 27th, 2010 12:22 PM #12
dude if you batt is ok and your alternator is ok din try to spray your air intake manifold or your SERBO mo sira na.. try to check to your mechanic alam nila yan kung ano problema nyan..
June 27th, 2010 03:00 PM #13
mga sir salamat..bili ako maya ng carb cleaner try ko linisin....update ko kayo.may servo din b ang carb engine?wala kc mechanic ng tito ko nasa subic nag coconvert dun...hehe..yung pinagdalhan ko na talyer near samin..wala naman ata alam inadjust nya lang fuel air mixture ganun pa din..salamat...
June 28th, 2010 03:22 AM #14
June 28th, 2010 03:52 PM #15
- Jan 2009
- 123
June 28th, 2010 04:33 PM #16Medyo OT here, sa Honda Wave bike ko, pagpreno ko namamatay ang makina. Binuksan ko ang karburador at nilinis ng kerosene kasi marami na palang parang putik. Nasolve ang problema. Sa kakilala ko, Honda Civic nya pagdinidepress ang clutch pedal namamatay ang makina, ignition coil ang culprit.
June 29th, 2010 05:49 AM #17
Posibling may leaked diyan somewhere. Kung hindi nagbabawas ng fluid at least you eliminated one of the probable cause. Now, check all following/ hoses for loose fitting, cut or crack, leaking brake booster, crack on the intake manifold, loose bolt or the gasket on the intake manifold are bad.
June 29th, 2010 02:27 PM #18
guy's solve na problem ko...buti umuwi na yung mekaniko ng tito ko.he just only do are repalced the hose of hydrovac to intakemanifold mejo may crack na, re-fitted the bolt/screw in carb mejo loose kasi,adjusted the needle screw of the floater counter clockwise (once) para di daw sakal sa gas and last spray nya ng carb cleaner all sorrounding ng carb..mukhang siraniko yung mga tao dun sa talyer na pinagdalhan ko.guy's salamat sa lahat ng advise..till next time..
Daming issue ng SU7:grin:
Xiaomi E-Car
