Results 1 to 8 of 8
- Jan 2009
- 8
January 3rd, 2009 03:28 AM #1just want to know bro kung ang gulong ba me saktong air pressure lang ba dapat??? yung tipong sakto na dapat lahat parepareho? o tantyahan lang kung malambot o matigas? 2 lang kami nang wife ko na laging sakay. jazz na bago auto ko. minsan me 2 sakay sa likod. nung last tym kasi dady ko nag drive sabi matigas daw gulong ko kasi matagtag. so binawasan nya konti. gusto ko lang malaman kung ilan ba dapat talaga ang dapat ko i-maintain na air pressue nang gulong ko??? ilan sa harap? ilan sa likod? kinse pala ang gulong ko. tnx in advance po!!!
January 3rd, 2009 04:04 AM #2
alam ko may naka indicate don sa may pintuan. ako i usually drive at 30 psi on all tires..
January 3rd, 2009 04:26 AM #3
check the sticker sa driver side door jamb. it'll give you the "advised" tire pressure. usually, the front tires are higher than those at the rear.
to some, they reduce the advised pressure by 2-3psi to make the ride less stiff. I personally keep it same as what the door jamb sticko says regardless if i drive alone, or drive jampacked.
hth
January 3rd, 2009 05:05 AM #4
yeah check the driver side, me sticker dun pre.
our jazz should have 32psi sa harap at 30psi sa likod. if you have just gotten the jazz out of the casa recently, chances are, they over inflate the tires talaga. nung nacheck ko nga nsa 40+ psi sya upon getting the jazz out of the showroom.
January 3rd, 2009 07:46 AM #5
Normally, pag kotse or sedan 28 psi. Pero, i-check mo ang manual or sticker kung ano talaga ang recommended ng car manufacturer.
:coffee: [SIZE="1"]4009[/SIZE]
January 3rd, 2009 08:40 AM #6
sa driver's side door pillar may aluminum sticker andun ang recommended tyre pressure front and rear. nasa car manual mo din yun.
make it a habit to read the manual, there are informations there that are very useful.
January 3rd, 2009 10:19 AM #7
The sticker in the door panel only indicate those on stock tires.
Personally, i had them at 35 psi on all fours. Tamad kasi ako mag-check. It would be months or when there is a perceptible "lambot" when I go for another refill.
- Dec 2008
- 3
January 3rd, 2009 07:35 PM #8mga bro.gusto ko bumili ng 2nd car .ano b maganda ?mern sa akin benta toyota gli 93mdl 150thou.sariwa at rvr n recon 110thou gas AT need p repainting please advice mga bro tnxs
Thanks sa reply mukhang decided na po ako what tint to install :) iniisip ko lang .. anong...
