Results 1 to 6 of 6
- Apr 2011
- 1
April 13th, 2011 08:55 PM #1mga sir need ko po ung mga opinion nyo..
ksi mabilis po mabawasan ung tubig sa radiator ng honda esi ko.
halos mga 30 to 40 kms ung tinakbo ko,ung reserve nya ubos ska meron bawas ng kunti sa radiator..anu po sa palagay nio ung problem ng auto ko?
- Aug 2008
- 24
April 14th, 2011 12:45 AM #2do see water dripping where you parked?
check the tubes... if you can't see it try to swab it with a tissue and you'll see if its dry or wet.
check radiator and resevoir caps.
April 18th, 2011 09:13 AM #3
April 18th, 2011 06:02 PM #4
Have the radiator, hoses checked ASAP. Baka itiirk ka niyan bigla.
What I did when I encountered the problem I changed the rad cap but meron pa rin naiwan water sa housing ng fan.
I bought evercool rad cost is around 5.5k year 09 ko binili.
Also do not use plain tap water. Please use coolant from CASA and distilled to top it off. Other coolant brands are too strong and not compatible with the metals inside the engine.
HTH
April 18th, 2011 06:14 PM #5
check your water pump in the morning as well if may leak na din. HTH
- Apr 2009
- 1,902
April 19th, 2011 01:42 AM #6Kung wala kang nakitang leaks gaya ng mga nasabi nila, then most likely yung coolant ay napupunta na sa loob ng makina: cylinder head gasket!
Make sure po na tightly sealed yung reservoir tank cap.
Otherwise, the steam will just evaporate in air.
Ano po kulay ng laman ng radiator?
If it's pinky slimmy stuff, then it's time to overhaul your radiator and replace the cylinder heat gasket.
Check the oil cap for slime.
Dapat puro oil lang ang nandun, otherwise it's certain na may tama ang gasket.
Been there, done that ... sakit po ng ESi yan!
Wag niyo na po sana patagalin.
[SIZE=1]Another tip: upgrade to 1.1 psi rating radiator cap[/SIZE]
Daming issue ng SU7:grin:
Xiaomi E-Car
