Results 21 to 30 of 31
June 27th, 2011 05:28 PM #21
- Jul 2009
- 3,604
June 27th, 2011 05:54 PM #22Mahirap sir GH lalo nung thursday. First time to be caught in a flood alone din so medyo nakakatakot hehe.
Nakapila kami lahat from the Makati-Mandaluyong bridge towards the city hall, and even while idle on the leftmost (highest) lane, umaabot na yung tubig sa exhaust... :O
- Jul 2009
- 3,604
June 27th, 2011 08:58 PM #24Haha. The funny thing is - by the time I found out - it was too late na.
The rightmost lane nearest to the sidewalk were flooded and continuing to rise while the leftmost lane w/c had a barrier was moving... straight into even deeper water.
I only got the 'courage' to ford the FD over the water kasi may nauna nang lovelife Corolla. =/
June 28th, 2011 12:34 PM #25
Yun lang. Anyways ingat palagi na lang and be wary of this areas. Plus remember that evry year it would only grow worse unless something is done drastically kaya kung 2hrs na ulan at babaha na, dapat next year 1:45 mins pa lang, alam mo na na babaha na. You must leave earlier.
- 52,729
June 28th, 2011 12:46 PM #26the water. either namuo ang grasa, o kinalawang ang metal. either way, nag-lock ang brake pads or nag-lock ang brake cable. try alternately pulling and releasing the handbrake handle with the button depressed, to release whatever got stuck. try also alternately stepping and releasing the brake pedal. hopefully, this won't repeat itself after the water dries out. if it repeats, you may have to open the brakes and lubricate them.
October 1st, 2011 12:54 PM #27
Question: What if you're currently driving through the flood, however wala talagang choice but to stop since all the vehicles in front of you stopped. What should I do (M/T)?
October 1st, 2011 01:25 PM #29
So upon halting to a stop, full depress na sa clutch while doing high revs? Then pag aaandar ulit, do a gradual release parin like normal driving?
Na lock ang Gcash ko, need verification pa and kasama sa list nila ang philsys ID paper, but when I...
National ID Law
