Results 11 to 20 of 50
September 13th, 2006 09:29 PM #11
since nasa CRV gen 1 topic na rin tayo, matanong ko lang, may ATF dipstick ba ang matic na CRV. Nung nabili kasi namin yung CRV anmin 2nd hand at walang manual na kasama. mahigit 3 yrs na sa amin yung sasakyan, ngayon ko lang naisip mag check ng ATF eh
September 13th, 2006 09:44 PM #12
not famillar with A/T since I had an M/T pero 3 yrs na yan dapat every 40tkm palitan yung ATF
- Sep 2006
- 5
September 13th, 2006 11:57 PM #14
joyep,
ATF: Automatic Transmission Fluid
if you have more questions about the CR-V you can register at HCP and post at the CR-V sub forum:
http://z3.invisionfree.com/HCP/index.php?showforum=29
may manual ako ng CR-V from may previous ride. pag nagregister ka sa HCP usap tayo regarding the manual
- Aug 2003
- 317
September 14th, 2006 10:52 AM #15hehe. same question kung pano check yung ATF ng AT na gen 1 wala rin manual yung sa brother ko.
anyone here experienced a problem with the rear differential?
September 14th, 2006 07:18 PM #17
what should one check if buying a second-hand gen1?
meron ba mga recall ang Honda on the CRV?
September 16th, 2006 12:28 AM #18
pag di napalitan yung rear differential fluid for a long time meron lumalabas na grinding or sometimes squealing noise kapag nakafullturn yung oto. solution is just to replace the rear diff fluid with Honda ATF.
meron recall yung earlier Gen1 CR-Vs released here. yung ignition switch yata yun or yung front SRS madali daw masira yung contact points possible na di mastart yung oto or di magdeply yung airbag. Honda even sent a letter to CR-V owners back then regarding the said recall. dadalhin mo lang sa casa yun before papalitan na nila during the PMS.Last edited by Supierreman; September 16th, 2006 at 12:32 AM.
- Aug 2003
- 317
September 17th, 2006 09:19 AM #19yup parang may umuugong dun sa rear differential when the 4wd kicks in.
may idea ba kayo where i can get the supporting brackets for the propeller shaft? kasi when we bought our crv late ko na napansin na walang propeller shaft, though nakuha ko na ito. di ko mapakabit kasi kulang ng 2 supporting brackets. when we tried connecting the propeller shaft, gumana naman yung realtime 4wd niya although maingay. di ko macheck kung meron nung grinding sound on full turn kasi ayaw ibaba ng mechanic yung car sa lifter. di ko mapacheck kung fluid lang talga yung problem until i get the supporting brackets. TIA.
- Aug 2004
- 20
March 19th, 2007 05:16 AM #20hello po!
i'm planning to buy a 2000 cr-v paguwi ko. 2nd gen sana kaso may iba pa akong pinaglalaanang gastusin. tanong ko lang sana yung mga variant ng 2000 model ng cr-v para mas macheck ko ng maigi yung mabibili ko. di rin kasi ako masyado familiar sa mga suv. this will be my first suv kung sakali.
actually, undecided pa rin ako between 1stgen and 2ndgen...parang gusto ko i-stretch pa yung budget ko...haay, hirap ng kulang ang budget tsk..
tia...
Did some independent research and decided to go with the white pearl crystal.... para maiba naman. ...
