Results 11 to 17 of 17
May 5th, 2012 12:07 AM #11
And sa panahon ngayon ts di na usi mga 13+km/L maski nga honda city nag8km/L sa city kasi traffic eh tapos mga 18km/L sa highway brand new pa yun
Alto at prius lang makakaabot ng ganyan unless sacrifice mo sarili mo w/o aircon which is really unthinkable sa weather na ganito
- Apr 2012
- 94
- Apr 2009
- 1,902
May 5th, 2012 12:08 AM #13Rechipping per se won't do much wonders. It simply readies the engine for real "tuning" to let the tuner modify your fuel and ignition map according to your modifications and intended application. On most Hondas, rechipping can only adjust the VTEC engagement point on the spot or lets you have VTEC (if done after a mini-me swap).
Remember, engine makes power using air, fuel and spark (ignition). Rechipping only won't modify them. Tuning will.
- Apr 2009
- 1,902
May 5th, 2012 12:09 AM #14
May 5th, 2012 09:44 AM #15
That's not possible ........ I own a 2000 Vti and I'm very satisfied with my FC. I wouldn't tinker the computer box to compensate my car's performance.
- Apr 2008
- 6,237
May 5th, 2012 08:56 PM #16Huwag na bro. Tinkering with the ECU may let you have better mileage. But I'm pretty sure it does so by retarding engine response. I suggest you do a thorough tuneup of your engine and perhaps get a K&N filter then drive smoothly. You'd get better mileage this way, and also a few more horses in the process.
May 10th, 2012 11:58 AM #17
With our current fuel na mayroon ethanol, na mabilis masunog at maubos & 1.6l displacement, malabo kahit 15km/l; only a diesel engine can accomplish 20ish because of diesel slow combustion & compression system. kahit palitan or reprogram ang ECU it will still balance the fuel to air ratio to make the engine efficiency, too much or little air/fuel, totope makina mo.
Suzuki JIMNY [merged threads]
