Results 1 to 10 of 10
- Apr 2010
- 2
May 31st, 2010 06:15 PM #1Mga PAPS and masters, I hope youll help me with my problem.. npansin ko kc ngtatagas sa steering pump auto ko, and ngtnung me sa isang car care center.. ang singil nila is 4700 palit daw ng steering pump repair kit (orig), steering fluid etc etc. and kasama na labor.. ask ko lng kung ok n b un? or medyo may kamahalan? ngtnung nmn ako sa alabang parts center kng mgkanu ung repair kit.. sabi nila is 1200 lng daw at orig.. any suggestion kng san mgnda mgpagawa at medyo mura? or sa FIXSTOP ba ok ba ipagawa dun? salamat mga masters
- May 2007
- 104
June 1st, 2010 03:53 PM #2
- Aug 2009
- 56
June 2nd, 2010 12:02 AM #3bili lang kayo ng repair kit sir kung alam nyo ang partstar sa may edsa rotonda right side pag papunta ng monumento,price nya 1,100 pero tawaran mo ibibigay sayo 1k,tapos ang regular talaga labor nyan sir ay 800-900 pesos,kasi pag hind nyo naagapan ang leak nyan tutulo yan sa drive belt lulutong yun magpapalit din kayo cgurado,kasi ganyan ang nangyari sakin,pinatagal ko muna nung maingay na sya saka ko pa lang pinagawa ayun na damage ang drive belt ko kasi natuluan ng p/s fluid
- Apr 2010
- 2
June 4th, 2010 09:37 PM #4mga paps, salamat sa advice.. tama sir ung presyuhan na nasabi ni sir sirhc77,
around 600- 900 presyo depende n rin sa mekaniko.. ngtnung me ng parts sa casa about sa Kit.. and its P1,016 to be exact and 550 sa fluid.. salamat mga paps sa advice.. thanks din sir mikhailer.. salamat po sa inyu
June 6th, 2010 12:33 AM #5
mga sirs,
Ito ba po yung repairs na kelangan ibaba yung Gearbox?
Kasi last time I was at the casa, they told me too that I had a powersteering leak. (BTW, I have a Civic 2001, not an SIR as in the original TS question) And true enough when I looked, there was really something wet where they pointed at. They gave me a quote: POWER STEERING GEARBOX KIT A = 1,920 KIT B = 530; LABOR = 2,380. And they said the work will last 2 days...kasi baba nga daw yung Gearbox.
Di ko pa napaayos kasi, nagka semi phobia ako kay casa because everytime I go there to have something fixed, they fix it...only to suggest another repair or maintenance elsewhere..but I realise na parang major work yung baba ng gearbox kaya nagresearch muna ako. Baka after they finish the work e next nila suggest e change something again. thank you.
- Jun 2010
- 27
June 6th, 2010 02:16 AM #6sir,ask lang..auto ko vti 96 model..ung steering wheel nya.mejo matigas pag ililiko..
lowered auto ko.17's ung wheel.normal ba un??
thank you in advance..
- Nov 2009
- 456
June 6th, 2010 12:17 PM #7Most likely normal ang pagbigat nya kasi mas malapad ang 17's kesa sa stock tires. Mas malapad mas malaki friction sa pavement. Check mo din power steering fluid kung nasa tamang level. Check din kung may langitngit or strange sounds galing sa pump (baka nahihirapan sya).
- Aug 2009
- 56
June 6th, 2010 03:17 PM #8sir yung power steering pump po mismo ang tatangalin,tapos bubuksan yun at papalitan lang lahat ng oil seals tapos ginamitan ng grinding compound,yun lang,saglit lang yun sir half day lang yun kasi nung pnagawa ko sakin pinanuod ko kasi sa maayos na talyer ako nagpagawa kaya binantayan ko kung paanu gagawin,hindi rin ako nagpapagawa sa casa kasi hindi ko nakikita yung gawa,saka mahal,1k plus lang ang repair kit sir at labor less than 1k din,
June 10th, 2010 10:22 PM #9
sirhc77,
thank you sir.. so if ever pagawa ko sa casa I'll try to insist na 1 day lang or less. And you're right, di mo kasi makita sa casa yung quality nung trabaho nila, di mo masilip. Ang isa pang naisip ko is just buy the repair kit from the casa & have it done by a knowlegeable mmechanic/shop elsewhere.
- Aug 2009
- 56
June 10th, 2010 10:55 PM #10tama sir bili lang kayo sa casa ng repair kit tapos sa labas nyo na ipagawa,sa casa sir pila kasi dyan by number kailangan maaga kayo kung gusto nyo matapos sa 1 day depende pa sa ipapagawa nyo,kaya ako puro pa check up lang at bili ng parts pag pagawa na sa labas na,meron na kasi ako suki service center dito sa amin sa imus cavite,mura pa saka mga galing casa ang mga mechanics
