Results 911 to 920 of 1000
- 52,731
August 11th, 2020 07:36 PM #911
- Sep 2016
- 2,278
August 11th, 2020 08:25 PM #912Ako nagpa 3.5 yrs PMS nung June sa Honda GH. Buti wala pa naman nakitang problema sa brakes. Kita ko yung ginagawa nila sa buong duration ng PMS kasi nasa tapat ng bintana sa lounge. Makapal pa rin daw ang pads. Nasa 25k na tinakbo ng Mobi namin. Good thing pa rin kasi covered pa ng warranty yang issue mo sir.
August 11th, 2020 08:36 PM #913
What might be the cause of drum brake cylinder leak? It seems to be unlikely for it to leak within just a span of 3yrs. Never did I encounter drum brake leak in my other ride more than 10yrs.
- Nov 2009
- 3,484
August 11th, 2020 09:31 PM #914^Corrosion. Brake fluid being hygroscopic pools the heavier water on the lowest part of the brake line which is the brake pistons/cylinders. This is why flushing by bleeding the four wheels every 40k or 2yrs is more important than superficial cleaning by using brake cleaner.
August 11th, 2020 09:57 PM #915
Oh okay I do change my brake fluid every 2yrs. What is the correct way to replaced the fluid? because one do the flushing and bleeding by stepping on the brake pedal repeatedly and I have seen another one they just suck in the brake fluid reservoir and replaced it with new one no flushing or bleeding.
- Nov 2009
- 3,484
August 11th, 2020 10:17 PM #916^Sucking is not the proper way, its only applicable for the power-steering fluid since it has no bleeder valve. Loosen the bleeder nipple of the brake cylinder, press on the brake pedal let it bleed to remove the old/contaminated fluid.
- Jun 2011
- 1,080
August 11th, 2020 10:30 PM #917Possible din siguro na "na-suwerte" sa factory defect. Madalas nga matagal, at least 5 years, bago maka-experience ng leaking brakes.
Oo nga, magandang suggestion isabay na ang brake flush. As per Honda schedule, 3 years or 60K Kms. Sa ibang cars namin madalas 20K Kms brake flush interval kahit na more than 2 years. Since 21K Kms na din, okay na isabay ang brake flush. Para hindi na gawin sa 3-yr PMS.
(20K Kms madalas bilang namin sa brake flush interval, mas tama ba iyong every 2 years?)
August 12th, 2020 09:24 AM #918
- Sep 2016
- 2,278
August 12th, 2020 03:02 PM #919
- 52,731
August 12th, 2020 03:30 PM #920
Daming issue ng SU7:grin:
Xiaomi E-Car
