Results 671 to 680 of 812
Tsikot Member Rank 3
- Aug 2004
- 2,452
April 14th, 2007 08:39 AM #671
May 7th, 2007 08:28 AM #672
Patulong naman bros.
Our Honda Jazz, acquired Oct., 2004, did not start this morning. It looks like the battery is dead. I plan on replacing the battery this afternoon. However, I undestand that I need to reprogram its CVT. From what I read, here's how to do it:
1. Start the car and run it to operating temp (no other electricals must be used like aircon, radio, power windows, mirrors, lights). Keep the doors closed so that the dome light is not on.
2. Shut down the engine
3. Start engine again and turn on headlights, without operating any other electrical load (other than headlights).
4. From P(ark), shift to N, D, S, L, S, D, N while waiting at least 2 seconds before shifting to the next position
5. Repeat the N, D, S, L, S, D, N sequence for 3 times
6. Turn-off headlights
7. Shutdown engine
Has anyone here personally reprogrammed his Honda Jazz CVT using the above procedure? Or do I need to do some more steps?
TIA.
2601:kick:
May 7th, 2007 10:14 AM #673
I did it once, but I remember the steps being shorter but I forgot the steps already.
I also changed my battery but didn't need to reset my CVT.
May 7th, 2007 10:25 AM #674
ask ko lang, bakit ni-rereset pa ang CVT? nagkakaprob ba kung di ginawa yan?
May 7th, 2007 10:52 AM #676
I've connected the - terminal first then the +. Don't know if there is a correct way of doing it. . . . I tried boosting it first to see if battery is really dead.
Exactly one year namatay ang battery. Tamang tama sa warranty.
May 7th, 2007 01:38 PM #678
Wala akong makita. Kaya ang iba,- ibinabalik sa casa para i-reprogram....
2601:kick:
Tsikot Member Rank 4
- 1,842
May 7th, 2007 02:01 PM #679napaka complex na talaga ng motoring nagyon
Even changing batteries needs some reprogramming thinga majing
I rather have regular A/T anytime
than hi tech stuff!
May 7th, 2007 08:00 PM #680
I changed the battery a couple of hours ago.
What I did was to remove the battery support first and then the terminal connectors last. I then immediately switched to the new battery.
I was hoping that there is a capacitor across the CVT memory that can hold its content for a few seconds. I then drove the car and did not notice any significant change in the 'shifting' pattern.
Anyway, I did the reprogramming steps mentioned above and drove the car again,- no change...
Could be also that the memory is flash nowadays....
2601:kick:
Monk-owned R53
