Results 71 to 75 of 75
- Feb 2014
- 6
June 27th, 2014 04:16 PM #71Why you do it when it's not even recommended by the manufacturer? I think change oil at 1k is good, i did mine at 1k pms after following motoman break in secrets.
- Jul 2013
- 41
- Jun 2019
- 17
June 10th, 2019 04:32 PM #74Hi. Tanong ko lang kung alin ang pwede ko irefuse dito sa 1st PMS ko. 2019 honda jazz, nung january ko nakuha. Wala pa 5,000 ang natatakbo.
LABOUR CUSTOMER 1,106.00
2PX OIL FILTER 454.83
Drain Plug Washer 30.25
SN 0W20 UNI 6X4L 2,763.40
PM KIT 325.00
CS KIT
MISC 338.00
GREASE,PAD(MOLYKOTE M77) 86.44
GREASE,PIN (NIGLUBE RM) 41.78
ENGINE TREATMENT 995.00
Perform [ ] Replace Engine Oil Filter
Perform [ ] Check Suspension mounting bolts
Perform [ ] Check Front/Rear brakes
Perform [ ] Check Air Cleaner element
Perform [ ] Rotate tires (condition,wear,press)
Denali Lights, Dial Dim, & Soundbomb Review—Is It Worth The Premium? | Behind A Desk MotoDeal
Auxiliary Driving|Fog Lamps
