Results 41 to 50 of 180
June 10th, 2010 03:53 PM #41
- Feb 2008
- 4
June 15th, 2010 08:35 PM #43
July 7th, 2010 06:24 PM #44
Tumawag ako sa Honda SPA: Php 1512 (may 15 percent discount daw kung less than 5 years old ang sasakyan; 20 percent discount kung more than 5 years old na.)
Tinext ko yung sa Honda Quezon Ave: Php 756 daw. Walang binaggit na discount. Yung replacement naman ng CVTF, Php 2600 daw.
robot.sonic
July 8th, 2010 08:55 AM #45
July 14th, 2010 11:04 AM #46
Parang di ko nabasa sa manual yung pag reset kapag nagpalit ng battery... ang nabasa ko lang ay ireset yung sa power window pag nagpalit ng battery. Aling manual ba ang tinutukoy? Yung binasa ko yung libro na kasama ng jazz. Owner's Manual ata yun. Tapos yung sa transmission oil, ang sinasabi pa don (atf-z1) ata daw ang ilagay.
Saan ba nakakakuha ng mas detailed na manual? Di na kasi gumagana yung link na binigay.
Salamat.
robot.sonic
July 26th, 2010 11:06 AM #47
July 29th, 2010 11:58 AM #48
I am not sure about what effect it will have as I have never tried it.
However, here's what I understand. The battery is there as a unit that is being charged and at the same time, a regulator in that it limits the output of your alternator at a certain voltage. If you remove your battery, then the voltage spikes somewhat. Now, I am not certain how the various electronic components of the car will take it....
Again, after replacement of the battery, I just did the procedure I stated above and I did not encounter any issue at all.
10.4K:shazam:
- Aug 2010
- 2
August 4th, 2010 11:59 AM #49
You just unregister the device where its currently installed.
National ID Law
