Results 1 to 10 of 55
- Jan 2006
- 224
February 23rd, 2006 03:11 PM #1Hi,
I'm sorry if there is a similar thread somewhere, but since I can't find it, I started a new one.
Regarding the CVT of Honda, I'm a bit confused about the 7-speed auto mode as compare to driving in just 'D' or 'S'. I understand that having the 7-speed mode in manual will allow you to control the gear setting of the CVT. So, what's with the 7-speed auto mode? Please enlighten me.
February 23rd, 2006 03:20 PM #3
those 7speeds are just small preset speeds for the City/Jazz...i really dont understand how it works coz a CVT is a gearless tranny, ironically that gearless transmission seem to have the highest gear ive ever heard pa (7speeds).
February 23rd, 2006 03:22 PM #4
I have not come across with '7-speed auto mode'. This could be referring to the 'D' position for AT. ['S' is sports mode.]
I'll check the manual tonight.
February 23rd, 2006 03:40 PM #5Originally Posted by Psylocke
On the contrary, for the Honda Jazz, the CVT works like this.
1. Normal Driving (D) uses the infinite ratios of the CVT with the intent of accelerating while keeping the RPMs down. S and L is the same thing but uses only higher ratios either to increase acceleration or to provide power at low speeds.
2. 7 speed auto mode - Press the 7 speed button only, the CVT will upshift and downshift automatically thru 7 pre-set ratios, just like any ordinary automatic tranny. Fun if you want to accelerate fast.
3. 7 speed manual mode - Press the 7 speed button and press the + - button on the steering wheels allows you to shift freely on the 7 pre-set ratios. It downshifts automatically but does not upshift automatically. You need to press the + to upshift. Very fun to play with.
- Jan 2006
- 224
February 23rd, 2006 04:45 PM #6Originally Posted by Mguy
February 23rd, 2006 05:04 PM #7
now, i truly believe da vinci is a genius! cvts have no gears and is much simpler in concept, it only utilizes a vbelt and 2 cone-shaped shafts which changes in diameter to change power output. yung 7 speeds, just like what Mguy said are only presets to specific "gear" ratios. imagine an fm radio where you can tune into numerous frequencies, you can preset specific stations to corresponding numbers sa stereo right, same idea with the 7 speed mode of the cvt
since the cvt does not use any gears but instead uses varying diameter pulleys, it can have an infinite number of gears so better efficiency
February 23rd, 2006 05:16 PM #8
there is...
on a cvt, d will use infinite number of ratio from its lowest to its highest ratio...kaya kung titignan mo specs ng CVT lagi nakalagay:lowest gear ratio to highest gear ratio..giving you the ratio to maintain low rpm while accelerating..
pag 7-speed auto mode, ung tranny, will shift to 7 preset gear ratio, ala 7-speed regular tranny
February 23rd, 2006 05:23 PM #10
kaya nga im pushin my sister to buy a jazz na eh...
baka next month daw...
any feedback for America Lumina Nano Ceramic ? which better between Sunblock Ceramic vs Lumina...
