Results 11 to 20 of 21
- Nov 2009
- 115
October 31st, 2011 04:33 PM #11It's the 2.0 liter A/T. So I guess it's the lower variant. Like I said before, the tire pressure is already 30psi, which is the recommended one by Honda. The shock absorbers or softer springs, does Honda provide this? I think they require any changes to be done from their end since the vehicle is still under warranty. Maybe for now, I'll be considering the padded leatherette seat covers.
October 31st, 2011 05:32 PM #12
Any change made to the vehicle's suspension will void the warranty only of the component changed or any components that may have been affected by the change. Busted shock that you had done outside? No warranty. Busted suspension bushings after shock change? no warranty. But busted headlight or alternator? No relation, so warranty will be okay.
I'm not quite sure, but I think the 2.4 and 2.0 have different suspensions, because, if I recall, the 2011 2.4 has a revised suspension that feels a bit softer. Then again, it may just be the extra weight loading the suspension down so it isn't bouncy and the leather seats absorbing the rest of the shocks. It's worth noting the current 2.4 has different tires, too.
Still, better if you get the shocks outside... Bilstein has applications for the CR-V, if I recall. But too early. Try the seatcover thing, and if that's enough, leave it be until at least 60-80k kms, at which time your springs will have softened up, or your shocks will be losing pressure... then decide.
- Nov 2009
- 115
November 1st, 2011 01:19 AM #13As for the suspension, I just checked Honda's website, both tires and suspension are the same. Except for the mags, the 2.4 is 5-spoke, while the 2.0 is 7-spoke.
Ok, maybe I'll just try the seat cover first. Have it with a leather and a padded seat cover then I'll try o see it first. Hopefully, I won't feel too harsh once done.
Tsikot Member Rank 4
- Jan 2007
- 2,326
November 7th, 2011 08:25 PM #14If you frequently ride alone, you can also try putting a bit of load (like 25 kg sack of rice) in the back -- tataas nga lang yung FC mo. Or, you can add O-Sulee at speedlab -- yung original ha. Huwag yung fake, rubber kind.
I used O sulee on my Ondoyed FXT and it has helped a lot with the noise. (Ride still is, and always has been, good).
- Jul 2008
- 754
- Oct 2011
- 22
November 10th, 2011 10:49 PM #16sir, i have heard about nitrogen gas used instead of regular air into the tires will help soften the ride, will it really help?
- Apr 2009
- 86
November 11th, 2011 06:32 PM #17talagang matagtag crv gamit 2.4 2010 model matic 30psi na lahat ng gulong pero matagtag parin
di gaya ng strada ko dati 2007 model mass maganda pa ride comfort kaysa sa crv ...pero sa ngayun sanay na ako
wala eh ganyan talaga yan ...........
- Nov 2009
- 115
- Nov 2009
- 115
November 13th, 2011 11:43 AM #20Napaka ironic, strada and crv are two of my choices before ako bumili. I chose crv kasi matagtag yung natest drive ko na strada. Pero nasanay na rin ako. Di ko nga alam kung sanay na ko o lumambot na yung shocks nya e. Naiisip ko na lang crv's handling is superb. Much better than strada.
Has anyone of you tried buying or installing front bumper that's made in taiwan (yung...
