Results 1 to 10 of 21
- Nov 2009
- 115
October 31st, 2011 02:22 AM #1Hi guys, I just noticed na may pagkamatagtag yung CRV. I just bought one last month. Can't help comparing it to our Isuzu Crosswind, which I think is less harsh. Just want to ask if there's someone out ther who experienced the same harshness of CRV, and did you do something to lessen yung pagkatagtag nya. Thanks in advance.
October 31st, 2011 08:43 AM #2
- Nov 2009
- 115
October 31st, 2011 01:24 PM #3
- Sep 2009
- 368
October 31st, 2011 02:12 PM #4
October 31st, 2011 02:38 PM #5
that is true. the tires are intentionally over inflated before leaving the assembly plant for two reasons:
1- to prevent flat spots on the tires during shipment and extended parking at the dealership,
2- to have better chances of not going flat while in transit.
the other possibility for a new vehicle harsh ride is failure of the pre delivery personnel to remove the rubber blocks on the suspension between the rungs of the coil springs. these blocks were installed to prevent sagging of the springs as they are tied down tight on the ship's deck
October 31st, 2011 04:10 PM #7
Which variant?
The CR-V is indeed stiff, but not categorically worse than the Crosswind... unless you're coming from an older XTO variant or a recent XT or XTi variant with the smaller tires... yes... those do ride more comfortably. The XUVi is just as bad, in my experience.
The lower-end CR-V variant has stiff and thin fabric seats. These amplify the harsh ride. The higher-end variant's leather seats soften it. If you have a lower-end variant, consider padded leatherette seat covers.
Check tire inflation. If it's underinflated or overinflated too much, that can cause a poor ride.
The easiest solution would be to change out the craptastic Bridgestone Duelers for better tires.
There's a possibility of curing the ride with better aftermarket shock absorbers or softer springs... but this is an unnecessary and major expense on such a new car.
- Nov 2009
- 115
October 31st, 2011 04:23 PM #8
- Nov 2009
- 115
October 31st, 2011 04:25 PM #9I actually had my mandatory 1-month service with Honda. I still encounter the same harshness. I'm thinking that if ever there's a rubber block on the suspension, they should have removed it already, am I right? Or do I need to remind them of this? How will I know if there's a rubber block on the suspension?
- Nov 2009
- 115
October 31st, 2011 04:27 PM #10
Daming issue ng SU7:grin:
Xiaomi E-Car
