Page 88 of 118 FirstFirst ... 387884858687888990919298 ... LastLast
Results 871 to 880 of 1178
    Mar 2013
    #871
    Well if that kind of testing and comparison floats your boat, then well and good. And if Caltex works well for you, then that's great. Honda CRV [continued]
    Interestingly, if you read on the "best fuel" threads, no brand is unequivocally good, and likewise, no brand is uniformly bad. Even for people with the same cars. Honda CRV [continued]
    Yeah. tire pressure, time of day, fuel source, traffic situation and even dirt on your underpanels affects fuel consumption that's why we can't or it's difficult achieve the perfect setup. Maybe on the dino but i'll wait for sponsors hehehe.
    I'll try Shell next time and see the difference. I'm reading positive comments on V-power.
    Feb 2003
    #872
    Quote Originally Posted by RC-V View Post
    After 16yrs, 100k mark reached. (gen2)
    Wow a garage queen as well mine is 5K++ before hitting that mark..though shes's turning 14yo hehehe. Dec. 2002 just replaced lang ang front disc pad...Luv this car will keep this as long as possible..Though lalo sya now natengga due to her sis Eve😌
    Mar 2013
    #873
    still using caltex platinum and mileage improving. from 7 highway now 12.5 max kanina lang
    12.2 nung kuhanan ng pic
    Jun 2008
    #874
    How many liters for engine oil change for gen3 2.0? any recommended oil filter aside from oem?
    I'm planning to use Zic x7 fully synthetic oil. ok ba yun? thanks bros!
    Dec 2009
    #875
    Hi, i have ha honda crv 2012 4th gen. Around 45k milage. Everytime i reach 35-45kph i notice the engine shakes. Anyone of you experienced this? Do you have a preferred mechanic? Qc area po. Thanks!
    #876
    Quote Originally Posted by jun_chan8 View Post
    is it the engine, or is it the tires?
    i have experienced this in my (non-honda) car.
    as it turned out, my tires were out of round (oblong, in the vernacular mechanic-speak). a simple tire replacement solved the issue.
    #877
    ^^^ Try to check the engine supports also.
    Dec 2009
    #878
    May preferred mechanic po b kayo? I just had the tires check a few weeks ago, wala naman daw problema sa gulong. Kinakabahan lang ako baka transmision bec. it usually happens after a gear change. What happens is, mag papalit ng gear then mag start sya manginig for a few secs. I have to step on the gas a little harder para mabilis mawala yung nginig, or wait until it passes.
    #879
    baka may part three pa ang revelation nyo, po.
    sabihin na nyo ang buong kuwento, para mas madaling mapag-isipan...
    #880
    *jun_chan8 - dr.d is right. Please share with us other symptoms you have encountered. Based on what you're saying, you may have some issues with your transmission. Kung andito ka lang sa Sucat area, puwede mo puntahan yung D&R Fast Auto repair shop. Sa Dasmarinas, Cavite naman andun si Mel Casaba.
