Results 791 to 800 of 1220
- Apr 2016
- 203
May 21st, 2016 06:12 PM #791
I brought the car to Honda Shaw, the service advisors looked at the front hood components and said they was no ABS (see picture, it should be present near the steering fluid container). Also when you started the car, there was no ABS on the upper left side. I think only CRV EX has it.. the CRV LX doesn't have it. When you have a car in front of you suddenly stopping in the middle of highway. Only ABS equipped car can make you adjust the steering. If you will manually step on the brake and release and step dozens of times a dozen a second or two.. it's not possible in that 2 second critical period when all you can focus is stepping on the brake.
Who else has no ABS in their CRV?
- Jul 2015
- 9,584
- Apr 2016
- 203
May 22nd, 2016 09:14 AM #793Big18. Do you know the minimum speed before the CRV would skid when brakes suddenly applied (like when the car in front suddenly stops or a person suddenly appears)? So I can keep it to the minimum speed for this backup car. For 12 years. I thought it had ABS so I could make it run at even 100 kilometers per hour.. but knowing now it doesn't have ABS.. need to just maintain that minimum speed when the car is still steerable when brakes applied suddenly. In emergency situation like the car in front stopping.. you want to apply brakes as hard as possible to make sure it stops. In split seconds you cant decide to do threshold braking (or releasing and stepping dozens of times a second or so).
- Jul 2015
- 9,584
May 22nd, 2016 09:39 AM #794
May 22nd, 2016 09:45 AM #795
For the abovementioned situations, a collision sensor would help you more than an abs. Only time an abs might be needed is when you are recklessly speeding on a wet slippery highway.
I always hate hearing an accident on tv where a driver reasons "biglang preno yung nasa harap ko e". It only means that the guy was driving too close without a safety margin. ABS won't avert it. But your not this guy because you care for safety.
- 52,731
May 22nd, 2016 09:56 AM #797
ako as a personal rule, i always maintain a one-car-length distance (at least) guide when i'm driving around in moderate speeds. and then i add more distance to the car in front of me as i drive faster ( wherever higher car speeds can be attained)
pero wala talaga abs iyong '12 crv model? naka k20 na kasi engine niyan kaya i expect abs equipped na siya kaya medyo nagulat ako sa sabi ni bro k_leos
- 52,731
May 22nd, 2016 10:04 AM #798yes, that ABS metal box with its cute metal tubings is hard to miss.
how's your third row, sir? is it front-facing, or jeepney style? if the latter, this may have been the special edition designed to take advantage of the tax-friendly laws for mass-carrier vehicles at that time. removing the ABS was probably another attempt at reducing the CRV's admittedly higher price, then...
when a rear fender and a front fender bump, the default assumption is that the car behind was following too close and/or too fast. "the only way i can think of to change this assumption, is to prove that the car in front backed up."
there's this three-second rule. at any decent speed, have at least three seconds of response time between your car and the one in front.
ABS can only help the driver control his vehicle. ABS does not make the vehicle idiot-proof.
heh heh.Last edited by dr. d; May 22nd, 2016 at 10:15 AM.
May 22nd, 2016 01:35 PM #799
- Jul 2016
- 14
July 9th, 2016 04:39 AM #800Hi,
Confirm ko lang. Mas matipid sa gas ang 2.0 vs 2.4 city driving right?
I'm looking forward to buy a 2008 CRV, either 2.0 or 2.4.
Mostly city driving lang.
