Results 631 to 640 of 1220
- Mar 2014
- 901
March 6th, 2015 12:26 AM #631On my opinion, I would suspect two possible factors regarding to your concern about the momentary flicker of electrical power on your car when another load activates. The followings are:
1.) Battery.
➡Not getting enough charged to stabilized current and voltage to your cars electrical needs.
➡Or it might be due for a new replacement.
➡Or underrated battery capacity to your car electrical needs.
2.) Alternator.
➡It might not be giving enough or sufficient current to charged your battery. Have it checked by your car electrician.
Sent from my Starmobile UP+ using Tapatalk
- 52,731
March 6th, 2015 12:36 AM #632
- Mar 2014
- 901
March 6th, 2015 01:16 AM #633
March 6th, 2015 03:23 AM #634
- Oct 2006
- 43
March 12th, 2015 10:31 PM #635Saan po ba na-aadjust ang cut-off line ng headlight for crv2014?
Para po kasing medyo mataas yung bigay ng ilaw. Kakahiya sa kasalubong pag gabi.
- Mar 2015
- 3
March 12th, 2015 11:58 PM #636Kindly check din mga fuse. I had an issue din last month nagfliflicker then me time medyo matagal un interval ng blinking. Checked wires and connection then finally na trace maluwag un fuse.
- Mar 2015
- 3
March 13th, 2015 12:00 AM #637Kindly check din mga fuse. I had an issue din last month nagfliflicker then me time medyo matagal un interval ng blinking. Checked wires and connection then finally na trace maluwag un fuse.
- Mar 2015
- 3
March 13th, 2015 12:12 AM #638Hello! Ask ko lang. May garalgal kasi na naririnig kapag umaarangkada crv ko. It happens kapag paangat kalsada. May humps sa mid way ng paangat na kalye dito sa amin, once i stop sa hump and then i start to accelerate to gain momentum saka cia parang gagaralgal (parang Grrrrruuuuugggggg un sound). Even at full stop tapos pwersahin ko un gas to have sudden acceleration gumagaralgal cia. Sound comes from the drivers side. It happens only when im stepping on the gas. After the garalgal driving seems normal naman na. Any ideas?thanks!
March 13th, 2015 11:28 AM #639
- Nov 2013
- 14
March 26th, 2015 12:44 PM #640Good day pips, I have a gen 2, and planning to have the oil changed and replace ung rubber head gasket (kase my leak according s casa) any recommended shops around makati n maayus gumawa? Salamat :D
