Results 1,161 to 1,170 of 1220
December 20th, 2019 04:51 PM #1161
- Jul 2015
- 9,584
December 20th, 2019 11:18 PM #1162
December 23rd, 2019 04:49 PM #1163
- Jun 2019
- 24
February 10th, 2020 09:11 AM #1164Guys i have 2012 CRV 4WD. Mga 1 month pa lang sa akin. It has 54k on the odo. After i got it dinala ko sa Casa for PMS. There are no problems with the car except there's a rattle that i feel sa steering wheel when going through some road imperfections or really bad speed bumps sa subdivision. I had it road tested at the Casa sabi nasa tires ko daw kasi low profile. I had since changed to thicker tires basically from 50 series to 55 series pero nandoon pa rin ang rattle.
I have a brand new car that feels solid at the steering wheel regardless of road conditions and with the same 55 series tires kaya sure ako na hindi gulong ang problema.
February 10th, 2020 09:42 AM #1165
Probable causes that you need to have them check:
- have them check the retaining collar for damage. lf it is damaged, have it replaced
- steering column ball bearing and the steering joint bearings for play and proper movement. lf there is noise or if there is excessive play, your steering column assembly has a problem
- inspection of the absorbing plates, absorbing plate guides and sliding capsules for distortion or breakage. If distorted or broken, the steering column needs replacement
Oftentimes, the casa just makes a quick assessment without challenging themselves to find the root cause of your concern. Am sure they have a more comprehensive list of probable sources to troubleshoot and pinpoint.
- Jun 2019
- 24
February 10th, 2020 09:49 AM #1166
February 10th, 2020 09:53 AM #1167
Have no answer, am sorry. Ang alam ko lang, is that ang specialization ng Cruven is to restore underchassis parts (injectable system). I don't think ma-trace din ng diagnostic scanner problem ng steering mo, mechanical kasi.
- Jun 2019
- 24
- Mar 2020
- 1
March 5th, 2020 02:50 PM #1169Hello Guys. Is this thread still alive?
Someone offered me a CRV 2nd Gen 2003 with 69KM mileage.
for 140K and on installment pa yan.
Is this a good deal?
- Apr 2020
- 1
April 1st, 2020 03:46 PM #1170
The 1.5G is good enough for me tbh My current car doesnt even have a rear camera and Ive never...
All New Toyota Corolla Cross
