Results 981 to 990 of 1220
- Apr 2016
- 203
February 6th, 2018 01:27 PM #981
Tibay naman ng radiator motor mo.. ilan mileage na gamit mo?
Ako 3 years ago while driving at Wilson.. bigla namatay engine sa road.. buti nasa tabi lane ako.. the passersby told me wala tubig.. so I asked for water from nearby store and after 15 minutes opened the radiator cap... then put water... the engine can shut down if either wala coolant or mataas temperature.. does the engine has separate temperature sensor or does it shut down based on the coolant temperature? Any radiator expert here? I don't know bakit nawala yun coolant (wala butas radiator that time).. ang nasira ko ay radiator fan motor.. pero if it won't run.. would the coolant simply evaporate first before engine shutdown.. or mauna engine shutdown before coolant evaporation?
Denso replacement nakalagay dun.. ang original ay Denso rin.. so question.. paraho lang ba yung denso replacement and original Honda na denso.. same parts no? or mas matibay pa rin sa Honda original.. why? meron fake na denso?
- Nov 2008
- 30
February 6th, 2018 02:41 PM #982Ang alam ko sir ang denso meron taiwan made approx 2k much cheaper than denso japan which is around 4k. Pero pinili ko ung japan made hesitant ako sa taiwan made although sabi ng binilhan ko parehas lang daw performance.
- Apr 2016
- 203
February 6th, 2018 02:56 PM #983
- Nov 2008
- 30
February 6th, 2018 03:00 PM #984Sir, 4.5k po ang kuha ko ng japan made from authorized dealer ng denso dito sa guiguinto bulacan
- Apr 2016
- 203
February 9th, 2018 06:30 PM #985Dear Honda owners..
I need to know something.
My radiator and upper/lower hose are all brand new made by Honda replaced last month. However, I noticed the coolant was still leaking (parang sa engine side). Anong meron (hose or tubes or pump?) sa loob ng engine that can leak? Any experiences regarding this? Salamat
February 9th, 2018 07:11 PM #986
May I know when was the last time you replaced the timing belt? If I'm not mistaken, you also replace the water pump together with the timing belt. If you didn't replace it, most probably that is the source of leak.
February 9th, 2018 08:36 PM #987
February 9th, 2018 08:44 PM #988
- Apr 2016
- 203
February 9th, 2018 09:05 PM #989I checked the clamps.. wala naman leak doon. Honda casa installed the hoses.. I saw liquid at floor below engine. Honda said they have machine that can check the source of leak daw.. for 1600 pesos diagnostic fee.. any idea ano klaseng machine ito? hindi ko daw makita machine. Monday ko pa pasok car pero in case meron kayo idea saan sa engine meron leak.. let me know so at least alam ko other possible sources ng leak.
February 9th, 2018 09:18 PM #990
