Page 39 of 62 FirstFirst ... 2935363738394041424349 ... LastLast
Results 761 to 780 of 1223
    Jul 2015
    #761
    Quote Originally Posted by elitebuckeroo View Post
    Guys, aside from the freebies below, meron pa ba binigay ang dealership niyo when you got your CR-V?
    STANDARD FREE ITEMS
    *3M TINT
    *FLOORMATTING
    *EARLY WARNING DEVICE
    *SEAT COVER
    *KEYCHAIN
    *RUST PROOFING
    *UMBRELLA
    *SET OF TOOLS
    *MANUAL LEATHER CASE
    *1,000 KM CHECK UP
    *15L GAS
    You can request for:
    Undercoating
    Visor
    and car cover?[emoji4]
    I got my unit from them not CR-V though, as for the license plate well it's been 5months of waiting and counting....
    Who's your agent btw sir?
    May 2009
    #762
    Planning to get a used 2007 crv 4x2. What are the common issues i need to look out for?
    Sent from my C6802 using Tapatalk
    Aug 2015
    #763
    All of the generations tend to be reliable, although, the 2007 model can have some issues. I suggest you check the power door locks, air-conditioning, and the automatic driver's window for any possible malfunctions. You should also check the tyres, since they tend to wear out quickly. If you have taken / plan on taking it on a test drive, check for any rattling sounds or loose parts.
    Other than that, try to look at the maintenance records to see if it was well taken care of in the past. Should that be the case, the car should not have any major problems.
    May 2009
    #764
    Timing chain na ba ang 2007 crv? 2.0
    Aug 2015
    #765
    Quote Originally Posted by kmb333 View Post
    Yes, it does use a timing chain.
    May 2009
    #766
    Got my crv earlier today, everything was functioning well. The owner misplaced the sparekey. Planning to have it duplicated. Can i start the engine using duplicate key from the mall?
    #767
    if it is just a key, i do not see why not.
    but if that key has some security electronics in it... malamang ay hindi.
    May 2009
    #768
    Question regarding 2007 crv electric power steering (EPS)
    While i was parallel parking my crv, the steering became harder to steer and the eps light comes on and off. Have you guys experienced this on your crv? Should i be worried?
    #769
    It wont start. You need to have the proximity sensor with the key. It should be near the key blade itself. I have to solder it out of the board when i comverted my key to a flip key.
    Jan 2016
    #770
    As long as you can try, go ahead. If it fails, then there must be a security feature or error with the duplicate.
    Feb 2011
    #771
    kaya na ng Mr. Quickie sa mall iduplicate ang transponder ng immobilizer. I think it cost 3.5k if I am not mistaken.
    Feb 2016
    #772
    Hello Honda lovers, need your thoughts about possible solution to my 2010 CRV automatic problem, the vibrations during idle is really getting noticeable now. done pms for 95k last nov.
    Nakakairita na yung vibration at P or N or D (stop by breaking) . Thanks in advance.
    Apr 2009
    #773
    Quote Originally Posted by Valentina2.0 View Post
    try to have your engine supports check.
    May 2010
    #774
    yung 2007-2010 pwede po ba lagyan ng 3rd row seat? kasya ba yung galing sa honda na katulad ng sa pic or pang 4th gen lang yun? thanks!
    #775
    Sa mga naka Gen4, may nag upgrade naba sa inyo to a bigger battery? Group 24 daw ang upgrade and papalitan yun tray according to crvowners website. Eto bang Group 24 ang equivalent ng 2SM na size locally?
    #776
    Na try nyo na po ba magpalit ng generic stabilizer link sa inyong CRV Gen2 na mabibili sa mga automotive repair shops. May kamahalan sa casa * P2k/pc as against P750 sa automotive shop?
    Worry lang kasi ako baka hindi ito magfit properly.
    Salamat po.
    Mar 2004
    #777
    Quote Originally Posted by mhanz794 View Post
    Salamat po.
    2T per piece is just about right. If you can afford original, get the original, aviod replacement stabilizer link. The replacement one will fit but it won't perform as well as the original.
    #778
    Thanks bro.
    Feb 2003
    #779
    Salamat po.
    No worries it would fit...This is the only parts aside sa serpentine belt ang napalitan ko sa Gen2 ko...so far its been 4years na and I think time for another replacement. To me this parts are not that critical in case it would fail so I just settle for a replacement. Other like Brake parts and belts need ko Orig for mind assurance.
    #780
    Hi Fellow Tsikot People,
    Im eyeing this 2014 CRV as a second car for my wife. Can anyone identify if this a Japan CBU. And can anyone tell if this unit has an econo mode and push start. Actually haven't seen the unit yet. Thank you in advance!
Honda CRV [continued]
