Results 371 to 380 of 1050
June 10th, 2003 06:33 PM #371
driver side lang yan... pag merong ganyan switch, di mo na kelangan i-lock then unlock (and vice versa) kung may mga ibang doors na unlocked pa... 1 flick of a switch nalang
- 188
June 10th, 2003 09:19 PM #373
yep ok yang switch na yan... hassle kase buksan yung pinto gamit yung right arm or left arm mo when you have to reach all the way back towards the corner of the window :|
June 11th, 2003 03:10 AM #374
sample, may passenger ka, bumaba, so open yung doorlock nya. so to lock it you have to unlock the door sa driver side den lock it or option 2 abutin mo yung door sa passenger to lock it. kaya medyo hassle pag alang central door lock.
June 11th, 2003 11:14 AM #375
pwede rin gumawa ng switch yun nga lang di na mukhang OEM. bibili ka nung switch tapos ilalagay mo dun sa mga nakaabang na lalagyan sa dash.
Kailangan lang ng relay.
Ok rin ito kase less hassle sa pagmodify pa nung Door sides.
June 11th, 2003 04:47 PM #376
sabi sakin sa honda qc in case daw maglabas sila around 4500 daw, medyo mahal nga compare sa labas kung ipapagawa mo juz what supierreman have said.
- 188
June 11th, 2003 07:16 PM #377ano ba idadagdag o papalitan? Baka naman switch lang? Mahal nga nyan kung ganon.
June 11th, 2003 09:02 PM #378
pag bibilhinnyo yung sa casa... papalitan yung door latch mismo... since mas maliit yun kailangan pa palakihin yung butas dun para magkasya yung bagong door latch with switch.
Check nyo baka kapareho lang nung door latch na yun yung para sa rear doors na nagooperate ng Power window (ano ba itsura nung Door latch sa rear?) kung tama yung iniisip ko na pang power window yung sa rear malamang pwede yun sa front pero yung switch yun yung mag operate ng central door lock.
Yung namention ko naman before na aftermarket switch kailangan gamitan ng relay.
- 91
June 11th, 2003 11:29 PM #379I hope you guys don't mind if I go back to the topic found several pages back regarding key duplication and the stock alarm of the 2nd gen CRVs.
I recently had my key duplicated in KeyCards in SM Megamall. I had the spare keycard made since I completely forgot about the claim by the dealerships that the supplied keys actually are embeded with a chip that is directly tied up with the alarm system. When I remebered this "exclusivity" claim, I immediately tried out my keycard thinking that I just blew P400 for a non-working spare. However, to my surprise, not only did the keycard open the doorlocks, it also completely disarmed the alarm and started my engine with no problems at all. Once done with starting the engine, I also tried locking the door again and arming the alarm. True enough, the car's alarm armed with a simple turn of the keycard.
Now, I highly doubt if there really is a chip in the dealer supplied keys. Medyo napapisip ako na there's a bogus claim regarding this issue.
- 68
June 12th, 2003 10:50 AM #380Originally Posted by bacon
Ang hindi ko lang alam ay kung saan mo nakita na may chips yung keys ng V dito sa pinas?
Sensing a hint of weakening on our 6yr old Thai Pana DIN74, went to the distributor to have it...
