Results 331 to 340 of 1050
Tsikot Member Rank 4
- 1,842
June 2nd, 2003 08:01 PM #331mukahanag power window nga
Anong gasolina gamit nyo mga pala?
Puede ba hindi unleadead?
- 1,842
June 3rd, 2003 12:30 AM #334
MAXBUWAYA,
lahat naman ng gasoline unleaded yun. yung iba na higher octane rating (like velocity, blaze) unleaded pa rin yun with other additives.
Ok lang gamitin yun pero para sakin unleaded na lang hehe mahal kase gasolina ngayon :?
- Jan 1970
- 6
June 3rd, 2003 12:30 AM #335"Puede ba hindi unleadead?"
What are your other alternatives MAXBUWAYA? Diesel? Whats wrong with petron blaze?
June 3rd, 2003 04:09 AM #337Originally Posted by Supierreman
June 3rd, 2003 07:44 AM #338
guys,,, is it bad if i convert my gas to leaded? unleaded kasi gamit ko then since binili ng dad ko yung crv ko unleaded na nilalagay ko...kung lagyan ko sya ng leaded hindi ba siya masisira?
peace!!
- Jan 1970
- 6
June 3rd, 2003 10:05 AM #339THERE IS NO LEADED GAS IN THE PHILIPPINES. Only unleaded and diesel. Well, the only leaded fuel is aviation fuel but i don't think you want to put that in your car. The catalytic converter will be the last of your worries if you use avaiation fuel!:wink:
- 1,842
June 3rd, 2003 10:49 AM #340kasi yung sa ECHO ko which also has a direct ignition , nagjejerk off pag unleaded na 93octane Nasira pa nga yung dalawang ignition coil then i switch to a higher octane, so far ok na.
Takot lang ako baka mangyari din sa CRV ko.
So the cae siguro is all gasoline here are unleaded the difference is in octane
ang minimum ng CRV dito is 92octane pero the lowest offered by our gas station is 93
Pero higher octane is better.
Oh well better switch to velocity or blaze.
*Yung SiR ko noon mas matipid sa gas pag high octane gasoline
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
