Results 641 to 650 of 1050
March 19th, 2004 11:18 AM #642Originally posted by Supierreman
dati yun when the officers tried that scheme.. but the members suggested na ibalik na accessible yung forums so yan ok na ulit
try to register and check it out if you have questions abaout honda stuff from tech to audio to detailing etc..
nagkita na tayo sa bigberts rgiht?.hehe. kung naalala mo pa.hehehe
- Mar 2004
- 18
March 20th, 2004 11:05 PM #644mine is a 1999 heather mist manual CRV...i had my headlight bulbs changed to 135W super white, changed my grille to those with 2 fog lights, placed a backup mirror, chromed door handles and mirrors and EGR tire cover...nothing else...
March 21st, 2004 01:10 AM #645
pasingit lang mga peeps, may feedback ba kayo sa mileage ng crv 4x4 AT mga ilan km/liter more or less? decided na kasi kami bumili next month. thanks.
March 21st, 2004 01:17 AM #646
xpac,
more or less halos pareho lang yung mileage niyan sa front wheel-drive model. (which in my case is ~5.7 km/L for A/T and ~6.5 km/L for M/T)
kung may difference, malamang maliit lang yun (like 0.1 or 0.2 km/L) at dahil sa added weight of the AWD system rather than because of the AWD function.
March 21st, 2004 02:29 AM #647
Crv peeps I need help,
I think I ruined our gen 1 crv real time 4wd system.
after reading tsikot's previos thread, I thought its about time I had our gear oil changed, mileage is around 38th kms. so I brought the car to the nearest gasoline station, Shell araneta ave. The mechanic said that honda uses ATF for the rear diffs not gearoil, We even checked the owners manual and he was right to use ATF.
After driving a few meters, we heard the rear diff start to grind, and it feels like the car keeps jerking forward. We drove about a kilometer and lefft the car to a friends house to minimize the damage. Were gonna have it towed to honda Q.A. this monday.
What happened to our CRV? anybody had any experience like this? I just hope that the damage isnt too severe, but I know i heard something break.
Tsikot Member Rank 3
- Dec 2002
- 551
March 21st, 2004 11:59 PM #648got this from a crv service manual.
Rear Differential AssemblY
Troubleshooting
Most problems in the unit are to be diagnosed by identifying noises from the gears or bear'ngs'
care should be taken during diagnosis not to confuse differential noises with those from other drivetra'n components'
Symptom Probable Cause Remedy
Will not go into 4WD mode . Fluid level too low
. Incorrect fluid type
. Add fluid
. Replace
Will not return to 2WD mode Incorrect fluid type Drain and fill the differential
Gear or bearing noises Fluid level too low
Damaged or chipped gears
Add fluid
Drain and f i l l the differential
Replace the differential carrier
assemory
Overheating . Fluid leveltoo low
. Add fluid
. Drain and f i l l the differential
Fluid leak Fluid level too high
Clogged breather hose
Worn or damaged oil seal
Damaged sealing washer
Loose mounting bolts or inade-quate
sealing
Lower to proper level
Clean or replace
Replace
Replace
Recheck torque or aPPIY sealant
1 5 -1 3
March 22nd, 2004 12:35 AM #649
johnart thanks or the info .
I hope i wont have to replace any parts.
Daming issue ng SU7:grin:
Xiaomi E-Car
