Results 11 to 18 of 18
- Feb 2014
- 2,536
November 1st, 2014 04:11 PM #11
November 1st, 2014 11:26 PM #12
ang problema sa type 2 coolant mahirap mag-hanap dito sa pinas. i sourced mine several months ago from an independent seller who had it imported from the usa pa when i decided to flush my old contaminated rad fluid
dunno why honda phil is still selling those type 1 coolants when it's already phased out in other countries
- Jul 2012
- 345
November 1st, 2014 11:31 PM #13mga sir panu kung puro tubig lang laman ng radiator at reservoir? masama ba yun? may nakita ako na coolant prestone 50/50 pwede ba ilagay nlng sa radiator un kapag napansin na konti na laman? same rin sa resevoir?
- Feb 2014
- 2,536
November 2nd, 2014 03:13 AM #14
well honda can be full of $hit sometimes but type-2 is available here in pinas. got mine from honda makati if i remember correctly. they dispense it from a drum so just bring your own container
by the way the type2 from the drum is a CONCENTRATE so has to be diluted 50/50 w/ distilled water.
November 5th, 2014 09:52 AM #15
^ it's good na available na din pala. kasi when i asked about it at the casa, they were scratching their heads not knowing anything about it. pati tuloy ako napapakamot na lang din
btw, how much did it cost you to get the type 2 coolant?
- Mar 2015
- 1
March 8th, 2015 03:49 PM #16Hi newbie here just want to ask if ok lang ba na distilled water lang ang gamitin ko sa radiator ko at walang coolant or dapat both meron? Honda Civic 2008
- Jan 2015
- 468
- 52,731
March 8th, 2015 10:05 PM #18one of the functions of coolant additive, is the prevent corrosion of the metal alloys in the engine.
Monk-owned R53
