Results 1 to 3 of 3
- 27
October 19th, 2009 04:31 PM #1Sir, help naman kasi ng linis ako ng engine, ung temperature guage ko ayaw gumana, bka kako sa censor san kaya makikita un, bka kako ngalaw ko.. tenks
October 20th, 2009 02:51 PM #2
'di ako sure kung iyong temperature sending unit ang nagbabasa talaga ng temp ng makina pero located siya halos sa ilalim ng distributor. not really that sure pero iyon ang maalala ko sa akin eh
October 24th, 2009 09:51 AM #3
If you try ground the wire and the guage sweeps to hot then the wire and guage are OK.
The sensor has to have a good ground connection where it threads into the manifold. If you busted the wire during cleaning your engine of course it doesnt connection.
Also check your thermostat. If it's stuck open the engine may not even be warming up enough to register on the guage.
And make sure the cooling system is full with no air locks. The sender is designed to read water temp, it cannot read air temp accurately.
Should be simple enough to figure out.
Best of luck!
Methinks the Battle of Carthage scene in Russel Crowe's Gladiator (yr. 2000) is a homage to that...
Traffic!
