Results 1 to 7 of 7
- May 2011
- 4
May 19th, 2011 01:40 PM #1Hi Everyone,
I have this thud sound on my 2nd hand honda VTIS 05' model when shifting to 2nd gear. It happens during the first few minutes of driving, pero after that mawawala na even when you accelerate hard. It seems parang kailangan pa uminit or mag circulate ng mabuti ang engine or trasmission fluid, not sure though pero ganyan and problema. Does anyone have the same experience before?
- Dec 2006
- 234
May 19th, 2011 04:54 PM #2i had a thud sound before when my engine and trany mounts were broken. the thud only happened when my A/T shifted usually up or down to/from 2nd gear.
- May 2011
- 4
May 19th, 2011 08:00 PM #3Actually i was thinking about engine mounts also, kaya lang bakit on the first few minutes of driving lang and after that wala na even if you drive continuously for hours. Does it help kaya if i changed the ATF as well as the filter?
- Dec 2006
- 234
May 20th, 2011 12:39 AM #4you mean it's a continuous thud and not just at the point of shifting? that doesn't sound like engine/trany mounts to me.
how's your ATF level and condition?
- May 2011
- 4
May 20th, 2011 08:34 AM #5Yes Sir, it's only on the point of shifting to 2nd gear from the 1st and nothing on downshift. And the intriguing part was that it will only happen once during the first few minutes of driving from start, i mean, after the thud sound, you'll never hear it again even if you accelerate up to the 5th gear and put it on a dead stop then accelerate, nothing. But once you park and turn off the engine for a few hours, it will happen again.
- Dec 2006
- 234
May 20th, 2011 04:00 PM #6best pa check mo na lang sir. Kung malapit ka sa Sucat, kay Mel Casaba mo pa check sir.
- May 2011
- 4
Monk-owned R53
