Results 1 to 5 of 5
January 6th, 2013 11:40 PM #1
Hi Tsikoteers,
Nag pa change oil ako kanina. Tapos napansin nila hindi pantay yung kain ng gulong ko sa harap. So magpa-wheel alignment daw ako, pero chineck muna nila ung mga pang ilalim, they discovered that my TRANSMISSION SUPPORT and SHOCKS MOUNTING (L&R) are already dilapidated and already for replacement. By the way, my ride is Honda City 1.3 iDSi 2008 Model. Ano po ba yung EFFECTS kapag hindi ko pa muna pinalitan yung SHOCKS MOUNTING and TRANS SUPPORT?
Yung TRANS SUPPORT nakita ko talagang ang lakas ng galaw ng makina kapag ini-start. kakatakot baka malaglag. Tapos yung SHOCKS MOUNTING naman po ni-lift nila tapos dapat daw hindi gagalaw yun. pero gumalaw sya angat baba nung ni-lift tapos inaangat nila yung gulong. Pero parang wala naman ako nakikitang prob dun. Sorry wala pa masyado alam Ano po kaya magiging probs ko? Salamat mga IDOL!
Sa mga experience po nito, magkano po kaya gastos sa TRANS Support and Shocks Mounting Parts and Labor sana! THanks! Happy New Year!
January 16th, 2013 05:47 PM #2
same thing here idsi 08 model. sa casa sabi shock mounting P3.8K-pair and damper stopper-P800-pair for replacement..
effect:1. mas noticeable daw mga bumps, tagtag, kahit pebbles sa daan...though di ko pansin kung di lang sinabi sakin.
2. uneven tire wear kahit normal alignment and balanced tires... di masyado pansin yun eneven wear sa gilid ng front tires. ~5% difference.
Mas mura replacement parts outside casa pero sabi ng mga iba mas recommended ang OEM parts pag pangilalim. replacement shock mount outside-P1.5k pair na...damper stopper P500-pair. sa Transmission support di ko pa naexperience yan.
1 Year na di ko pa pinapagalaw...no problem whatsoever, will replace sets of tires before summer so maybe dun ko na lang din ipareplace yun siad parts.
January 16th, 2013 08:39 PM #3
ganyan din palagi problema ng gd ko. shock mount at lower arm assembly. 1332 ang shock mount sa casa. 1350 kay hrc banawe. ipapagawa ko na lang sa zee carplus. kasi kung sa casa, mahal labor at alignment.
nung sinabi sa akin ng casa na for replacement na daw, 1 year ko bago pinaayos. pinalitan ko ng replacement parts yung shock mount at lower arm bushing lang. after 1 year, sira na naman daw. halos 1 year na naman bago ko ipagawa ulit. sobrang noticeable na nga ang tagtag.
January 17th, 2013 08:52 PM #4
Same unit tayo TS at same din ng problema sa Transmission support yung akin small crack na ga Hairline lang naman daw ( di ko na chineck kasi nagmamadali ako nung nagpa change oil ako). quote sa akin 4.5k ata plus labor.
sa Honda SPA ako nag gawa.
BANNED BANNED BANNED
- Oct 2004
- 128
Methinks the Battle of Carthage scene in Russel Crowe's Gladiator (yr. 2000) is a homage to that...
Traffic!
