Results 11 to 20 of 20
February 23rd, 2012 01:36 PM #11
2010 City huh, curious, does the engine malfunction lamp turn on?
Could it be that the accelerator pedal sensor or the electronic throttle controller got fried? that's why it's always on idle.
keep us posted sir. I also have a 2009 City.
- Jan 2008
- 4,726
February 23rd, 2012 01:48 PM #12electronic throttle na ba yan engine mo or manual throttle pa?? yung TPS try mo disconnect then observe
February 23rd, 2012 01:50 PM #13
- Dec 2008
- 8
February 24th, 2012 01:01 PM #14Yup electronic na po.
The car got flood sa Sendong.
How much would it cost , TPS, in Manila. I can ask my brother to buy it for me. Would you know guys know any shop where i can secure one.
Thanks for all the reply by the way.
February 24th, 2012 01:26 PM #15
- May 2012
- 6
May 30th, 2012 09:11 AM #16assuming na working fine 100% ang ECU mo.. if you want to narrow your troubleshooting na nasa throttle body parts ang problem kelangan mo masigurado muna na hindi sira yong temperature sensor. now, merong 2 types of temp sensor either a temperature switch or a PT100 di ko alam kung ano nakakabit sa auto mo. pakiverify na tuyo ang terminals. Or it might be the accelerator pedal sensor na magsesend ng signal na gusto mo magaccelerate. Again assuming na 100% fine ang ECU mo.
May 30th, 2012 09:27 AM #17
your car's controls is that of throttle by wire. there are two throttle sensors (TPS). one at 5 volts signal and the other at 0 volts at idle. they are opposites when it comes to signal output. each of the sensor have three wires 1. sensor ground, 2. reference voltage of 5 volts, 3. signal voltage that varies with throttle opening. the sensors are sealed and supposedly air and water tight. the connectors are weatherpack but sometimes water gets in and cause corrosion. with the ignition switch off, disconnect the sensor connectors and verify that they are dry and free of corrosion.
- Jul 2010
- 2
August 15th, 2018 11:43 AM #18
Guys, this is happening to me right now. I'm driving a Lancer MX 2003 matic. I press the accelerator and nothing happens even when your in P,R,N, or D. I brought to a car shop in Don Antonio QC for scanning and then the mechanic told me that there is "LINE PRESSURE SYSTEM FAILURE" HE said that I have transmission problem that I need to change my whole transmission.
Is this right? TIA
August 15th, 2018 12:38 PM #19
- Jul 2010
- 2
August 15th, 2018 04:55 PM #20
What vehicle and what's your budget?
