Results 21 to 30 of 36
July 5th, 2008 08:14 PM #21
I think I was somewhat responsible.
Anyway, I think he is just making sure you do your tune up before having the LPG system installed. Also the type of auto-lpg system you will be using works best with a fresh/new air filter (and remember to keep it clean regularly). A dirty filter will cause the air-fuel ratio to get screwed up.
Reason is our City overheated (not lpg related) and started to run roughly on LPG after but it would run almost normally on gasoline. After days of trying to diagnose the problem, it was fixed simply by replacing all the sparkplugs. It was a problem which could have been avoided if it had it's proper tune up.
July 6th, 2008 09:44 AM #22
Hi GH,
thanks for this useful infos. i guess mas maganda pala palit lahat air filter, new spark plug ( resistor type) para hinde magka problema pag kasa ng lpg kit. did you also replaced it with resistor plugs as what BIGmike have advice me? thanks.
July 6th, 2008 03:55 PM #23
July 10th, 2008 05:51 PM #25
Sir GH question po, up to you if you'd like to answer this or not, just curious what made you choose GreenFuel, share naman.
On the plus side, I like how the Fuel Filler was discreetly installed, is this compatible to most refilling stations.
July 10th, 2008 06:19 PM #26
I have checked out other auto-lpg installers (although not all) and listened to whoever was in-charge of the shop/garage (I still do). I also checked out some samples of their work, current or finished in terms of fitting, wiring, quality of bracketing, etc. Typically I just walk in and do an inquiry without telling them I am from tsikot.com etc.
I also take note of the kits they have, options for those kits (tanks,etc) and the prices they charge.
I just keep my flapping trap shut long enough and listened closely to filter through the PR B.S. from the real data.
Then weigh which one "feels" better over the other. Kit prices is only one part of the whole picture.
On the plus side, I like how the Fuel Filler was discreetly installed, is this compatible to most refilling stations.Last edited by ghosthunter; July 10th, 2008 at 06:29 PM.
July 13th, 2008 03:30 PM #27
anong model 'yang city mo, gh? under warranty pa ba?. . .i've been to 2 (yet) honda cars dealerships and was told at each shop that the warranty would be voided if i bought one and installed an lpg kit in it. . .
sa toyota ortigas ganun din ang sinabi about the vios, although dun daw sa entry level ng avanza, which they are promoting for taxi use, e meron na raw naka-abang for lpg kit installation. . .
sigh, when will they ever wake up? . . .
- Jul 2008
- 11
August 1st, 2008 08:16 AM #28GH, im considering a convertion on my Civic SiR, what kit is recommended? thanks for your input.
August 1st, 2008 10:47 AM #29
Is the SiR equipped with an O2 sensor?... if yes, SGI would be the better option although the venturi-mixer kit would also run fine with the B16a engine.
The SGI-LPG auto-lpg kit would retain more of the B16a's original power.
The venturi-mixer kit would result in some increased vacuum pressure in the intake manifold. Although not dyno verified but I assume any increase in vacuum pressure at the intake manifold would result in decrease in engine performance.Last edited by ghosthunter; August 1st, 2008 at 11:00 AM.
- Jul 2008
- 11
August 1st, 2008 05:20 PM #30thanks for the reply Gh, there is none, but we put an 02 sensor when it was tuned after rechipping, 02 sensor was pulled out after the tuning. Should i get an 02 sensor first? The SGI-LPG auto-lpg kit is what im considering.
