Results 1 to 10 of 10
- Dec 2006
- 234
April 26th, 2010 09:47 PM #1Hi,
I have a Honda Accord 97 and the Automatic transmission no longer shifts smoothly. From 1st gear to 2nd gear ang lakas ng kadyot pag nag shift. Same with 2nd to 3rd and 3rd to 4th, pero mas mahina na yung kadyot. Ok din naman yung ATF levels... yun nga lang hindi pa ako nag papalit ng ATF since January 2010.
Before I bring it to a mechanic, do you guys have any ideas on what could be wrong?
Thanks!
- Jun 2004
- 1,311
April 26th, 2010 10:04 PM #2how long have you had the vehicle? any history of being flooded?
what brand of atf did you use?
April 26th, 2010 10:19 PM #3
Magpalit ka na ng ATF fluid mawawala problema . Makikita mo naman sa kulay ng ATF fluid mo kung brown na ang kulay karamihan pula ang kulay pag sariwa pa ang ATF fluid mo. Sa shell service station mo na lang paggawa para malinis tuloy filter ng transmission mo.
- Dec 2006
- 234
April 27th, 2010 04:16 AM #4no history of being flooded as far as i know. try ko mag palit mamaya sa shell.
balitaan ko kayo. Thanks!
- Dec 2006
- 234
April 27th, 2010 06:02 AM #5Malakas din yung nginig nya pag naka engage (1,2,D3,D4,R) at naka idle lang, pag naka Neutral wala naman nginig ... ATF lang din kaya katapat nun?
- Jun 2004
- 1,311
April 27th, 2010 06:29 AM #6yung vibration more of sa engine supports, i would suggest honda ATF gamitin mo... mas mahal lang nga un
April 27th, 2010 08:02 AM #7
i agree w/ bro chris d. medyo nangingilala ang mga honda tranny kaya honda oem atf talaga ang recommendation ng mga honda users pag dating sa atf replacement.
bili ka nalang sa casa tapos sa labas mo na palagay para makatipid
hth
- Nov 2007
- 329
April 27th, 2010 08:37 AM #8i've experienced this.. but even after changing ATF, there was barely an improvement.. the problem was actually the engine support. one of them was worn out na. It was also why merong vibration. Pagka-palit ng engine support, nawala ang vibration, and i cant tell na it shifts unless i see the tach needle drop.
i don't know with your case though. try changing the ATF nga. If ma-solve, then good.. but if not, check your engine supports if ok pa. try starting your car with the hood open. have somenone shift the lever from D and R back and forth while you look at the engine. If the engine moves around a lot, theres something wrong with your engine support...
- Dec 2006
- 234
April 27th, 2010 09:23 PM #9Changed ATF this morning sa Shell lang, it improved a bit. Next I'll have the engine supports checked.
- Dec 2006
- 234
October 22nd, 2010 04:25 PM #10update lang, nag palit na ako ng lahat ng engine support, basag na lahat except yung sa driver side. ok na sya ngayon, hindi na nanginginig. Thanks sa lahat ng nag reply
