Results 11 to 15 of 15
- Mar 2007
- 16
March 26th, 2012 07:59 PM #11sir ganyan din po sakin 98 honda crv...kumakadyot sa 3rd gear,eh pina rebuild ko na un tranny pero may kadyot pa dn...ngaun un servo ko may prob kahit bagong linis na throttle body at iacv...im planning to buy a new servo pag nagka budget kc medyo mahal din sya...pero i dont think sa servo yung kadyot na yun eh...bka sa tranny pa din nga eh...
March 26th, 2012 08:27 PM #12
to all of you who are leaning towards blaming the IACV, bear in mind, the I in IACV stand for idle. the symptom appears more in third gear according to the TS. the closest to the problem are gearhead and barako ba ma. the problem is in the secondary or high voltage side of the ignition. this is easy to confirm, borrow a good set of distributor rotor, distributor cap and spark plug wires from a good known car. this is the most likely cause of the surging. the idle air control valve intake is neglible when the throttle plate is more than 20 % (third gear) when the surging happens. and the transmission proposition, is more work, more cost compared to confirming using borrowed ignition parts mentioned earlier.
- Nov 2010
- 6
March 26th, 2012 11:24 PM #13Mga sir, ginamit ko ang tsikot ko kahapon sa SLEX at wala akong naramdaman na kadyot kahit nasa 3rd gear ako biglang nawala di ko alam kung bakit.... takbo ko sa SLEX 80-90kph lang, pag dating ko sa alabang medyo mabagal na ako sinubukan kong mag 3rd gear na.... wala akong naramdaman... at isa lang ang napansin ko pag sagad ko ang tapak sa gas na nasa 3rd gear kakadyot sya...kaya ginawa ko tamang timpla nang clutch at gas kaya walang kadyot....
Dinala ko sya sa mekaniko, ang sabi sa akin palitan na raw iyong servo doon daw ang problema, ok naman daw ung iba....
*jick.cejoco
Sir, I will consider your suggestion.... sasabihin ko sa mekaniko ko....and I will give some feedback pag 100% nawala ung kadyot......para din sa ibang may problem na ganito.....
salamat po......
- Apr 2011
- 44
April 18th, 2012 10:22 PM #14Pa-check mo ung timing kung kc ung saken mahina umarangkada date yung 3rd gear.. yun pala timing lang... just an advice naexperienced ko lang...
- Nov 2010
- 6
April 19th, 2012 10:37 AM #15sir, maraming salamat.... nawala na ung kadyot nang sasakyan ko.... di ko alam kung bakit.... pinapalitan ko ung cylinder head gasket kase sira na talaga at deretso pa wheel alignment.... as of now nawala sya.....
anong timing ung cnasabi mo sir.... para matanong ko sa mekaniko din... ?
