Results 31 to 40 of 44
- Nov 2008
- 24
January 7th, 2009 12:02 PM #31
Thankx bro...cge puntahan ko yan, hindi naman sya nag bblink, steady lang naman..need mo lang talaga diinan yung gas para kumagat yung reverse and drive..then pag nasa 3rd and 4th gear ka na, smooth and steady na sya, basta every time na pupunta ng 1st and 2nd gear delay ang revolution, pagtapak mo sa gas, after 4 seconds ska pa lang sya mag rerevolution, parang nang hahamon ng karera lagi...hehehe
January 23rd, 2009 05:23 PM #32
naku, I'm also planning to buy a 2nd hand accord vti (97). though the only difference is that I'm eyeing for a manual tranny. however, it's still a used car and most likely parts will get busted soon.. paano kaya pag walang kakilalang mechanic? puwede bang ipatingin sa repairs shops tapos ipapacheck lang kung may sira? papayag kaya yung owner ng ganung set-up? is it still advisable to buy a 2nd hand '97 accord VTi?
January 24th, 2009 03:26 AM #33
Its a good idea to always bring someone know's about car, I mean the real one not those "wanabe", or bring it to the shop to have the car inspected. If the owner refuse to do so, then walk away almost always there's something fishy. Dont take any words from theme (seller) its always the good word on thier side next time you know.....its a disaster. Do your part to avoid common mistake.
- Aug 2008
- 48
January 28th, 2009 11:31 AM #34wag ka bumili sa banawe or evangelista dahil palyado din ang mga yun.
I know exactly what is the problem on your transmission, may kilala rin ako na bumabanat nyan, trained sa Japan with complete special tools and diagrams.
Initially, ang problem nyan sir pag walang reverse ay sunog ang 4th clutch dahil magkasama clutch ng reverse at overdrive clutch.
65,000 talaga paoverhaul nyan pero sa kakilala ko mga 35k lang may warranty pa.
- Aug 2008
- 48
January 28th, 2009 11:39 AM #35
- Aug 2008
- 48
January 28th, 2009 11:41 AM #37
- Aug 2008
- 48
January 29th, 2009 11:06 AM #38
- Dec 2008
- 50
May 22nd, 2009 12:35 PM #39what if convert na lang sa manual? mas madugo ba or mas magastos? afaik, manual trannies are more economical in terms of maintenance and fuel economy. suggesestion lang.
- Aug 2009
- 56
August 31st, 2009 12:03 AM #40
Monk-owned R53
