Results 31 to 40 of 46
February 17th, 2010 12:10 PM #31
February 17th, 2010 01:37 PM #32
So would this be the upper rad hose or the lower rad hose? hehehe.
I hope niwde11 can source a white faced vacuum gauge. If not, maybe the black faced ones won't look so bad. I'm just trying my luck on white faced gauges since the Jazz does come with white faced gauges as standard
February 17th, 2010 02:00 PM #33
Upper hose is usually the hotter one. If you want the temp reading to be engine water temp only, you can use the bypass hose (usually at the thermostat), which stays at engine temp. If you tap a radiator hose, the temp might go down when the thermostat slams shut.
February 17th, 2010 02:06 PM #34
February 17th, 2010 02:44 PM #35
Please text or pm me on their availability sir. I'm looking at a temp, volt, vacuum combo sana.
Thankis!
February 17th, 2010 05:56 PM #36
February 17th, 2010 07:15 PM #37
August 31st, 2010 01:19 PM #38
I got my gauges from niwde11 for a few months now already. Vacuum, volts, and temp. All by Circuit, all with white faces, terno sa sa Jazz. Still haven't gone to the install portion.
Good news, my radiator guy can fabricate a radiator hose adaptor for the Jazz.
But no one makes a good pillar mount for the Jazz so I'd have to contend with pod mounts and line them up on the left side of the dash angled towards the driver. Not optimal but allows the wires to be tucked away on the left side. Don't want to put gauges on the center and have wires running the length of the dash or have to bore holes in it.
August 31st, 2010 01:34 PM #39
meron ako dati napagtanungan gumagawa ng pillar pod(although for a sound setup ng tweeter) sa cainta lapit lang sa eastwood. almost tapat lang sya ng gate ng vista verde. well known sya sa kotseaudioclub.com. nawawala ko cell number nya. try to inquire at the site o kaya mismo sa shop nya. hth
yung pillar pod ko up to now di maperfect nung tao ko. yung una sagabal sa viewing kaya niremedyuhan ule, hehehhehe
August 31st, 2010 11:51 PM #40
The ready made pods costs Php200.00/ea. And medyo mahaba naman yung dash ng Jazz from base of windshield to top of side a/c vent so ample ang space. Pwede na siguro yun. I'll just 'park' them diagonally there.
Monk-owned R53
