Results 21 to 30 of 46
February 16th, 2010 10:47 PM #21
OTEP,
Mas mahal pa pala sa Speedlab, the radiator sandwich adapter is like PhP850 while the oil filter sandwich plate is PhP1500. Hmmm.
They also make a 3-gauge pod cowl for the GD Jazz that goes on top of the center A/C vents. It's made to look like the cowl for the main gauges.
http://www.speedlab.com.ph/otheraccessories.php
Those are cheap gauges by the way. Where are you buying them from? I've always wanted a voltmeter for my own Jazz, seeing as the car is more reliant on electronics than a lot of older cars - even the steering is electrically assisted.
February 17th, 2010 06:36 AM #23
Speedlab can handle everything from start to finish if budget is no consideration. Plus they have great facilities so I guess its fair for them to charge what they charge.
Circuit brand gauges are not really high end. These are not DEFI or Autometer. More like basic versions of AutoGauge. I use their boost gauge on the Patrol. The last jeepney I rode had black faced Circuit brand gauges. hehehe.
I'll PM you where I purchase my gauges in Quezon City.
February 17th, 2010 08:29 AM #24
otep; i think you know loud of 4x4ph. when i am planning to install a mechanical temp gauge on my lc71 project, he advised to me to put the probe in the cylinder head since(afair) it is the place where the real temp of the engine(real time). pag sa may hose daw ng radiator e medyo malamig etc. imo, medyo logical sya. so i just altered the connector of the heater hose(since nakablock lang sya). ill try to post the picture if you want.
btw, we can supply you circuit gauges if you happen to be in Bulacan. medyo by order basis nga lang yung mga di mabile like turbo gauges. afaik marami pa iba gauges. wag nyo sama EGT kasi kahit ako naghahanap sa kanila kaso wala raw sila stock nun.
February 17th, 2010 08:39 AM #25
February 17th, 2010 09:05 AM #26
Sa Feb 21 pa uwi ko ng Bulacan, and Sunday ata iyon. Can you supply me with a Vacuum gauge po? Hindi naman po nagmamadali.
Short of boring the cylinder head, the next best place would be the radiator hose heading INTO the radiator. The worst place would be the rad hose where the water flows going from the radiator back into the engine as the water has been cooled already.
Now which hose on the city/jazz is the hose where water flows from engine to radiator? The upper or lower one?
February 17th, 2010 09:46 AM #27
will try to contact if meron sila vacuum gauge.
di ako masyado pamilyar sa engine ng jazz. but if you can locate yung butas kung san nakakabit yung hose ng heater(if any) dun ka na lang tap. same princilple as the one na gusto mo gawin sa hose ng radiatorl.
February 17th, 2010 10:18 AM #28
On the Speedlab installation write-up for the Jazz, they installed the radiator T-junction at the radiator hose just before it drained into the radiator itself. This way, the probe will detect the temperature of hot water/coolant.
Had the T-junction + probe been installed after the radiator, that would have made the probe's readings useless as it will just pick up cold water/coolant temperature.
Just trying to explain the logic of this route
February 17th, 2010 11:01 AM #29
February 17th, 2010 11:38 AM #30
yup i know. thats why otep is asking which radiator hose. unlike sa heater hose, afaik kahit alin dun ay near engine temp compared sa rad hose. but kung saan madali and convenient as long as it works. di naman natin need ang "very" accurate reading as long as it gives the proper temperature resonse.hth
Mazda 3 is incredibly tempting, unfortunately the hybrid is not included in the coding exemption...
All New Toyota Corolla Cross
