Results 1 to 7 of 7
- Sep 2010
- 17
December 23rd, 2010 05:50 PM #1Mga sirs, hingi sana po ako ng tulong. Kasi po pag pinapaandar ko yung auto namin, tapos after mga 2 mins, may naririnig po ako na ingay sa distributor (yun po ba yung kinakabitan ng high tension wire katabi ng makina?). parang dumadaloy na kuryente / tunog dinamo, pero medyo malakas mga sirs. normal lang po ba yun? hindi ko po kasi napapansin yun dati. ano po kaya yung may problem dun?
civic '96 po pala yung auto namin, a/t
Thanks in advance mga sirs.
- 52,731
December 23rd, 2010 06:00 PM #2that's probably just the high voltage, arcing thru the contacts. i agree, you don't normally hear it. if you are engine-savvy, you can probably open it and clean the contacts. you can also see if the cables are installed right, that is, not loosely, hence the arc. and don't do this with the engine running..
- Sep 2010
- 17
December 23rd, 2010 06:06 PM #3Sir dr.d thanks po. So bale normal lang po yung tunog na yun? bukas po kasi uwi kami Batangas, ok lang po ba na ibyahe yun?
Thanks po
December 23rd, 2010 06:25 PM #4
December 23rd, 2010 07:08 PM #5
Check mo rin high tension wire mo sa katagalan at minsan hindi mo napupuna nabalatan na wire kaya may naririnig kang lagitik na tumatapon na kuryente.
- Sep 2010
- 17
December 23rd, 2010 08:32 PM #6Sir iridium / Sir speed unlimited, thanks po.
Sayang nakauwi na yung kakilala namin na mekaniko, next week ko na lang po ipapa-check.
Pano po kaya yun mga sirs, ok lang po kaya ibyahe yun? kahit meron naririnig na tumatapon na kuryente?
Thanks po
- Dec 2010
- 87
December 23rd, 2010 10:11 PM #7ganito ang simpleng test jan na hindi ka na mag hahanap ng magaling na mekaniko. Kumuha ka ng portable water spray gun. tapos i set mo sa pinaka fine mist ng tubig yung pinong pino na tama lang mag fog. tapos spray mo yung part ng distributor, spray mo ng konting tubig habang umaandar ang makina. Makikita mo kung san tumatalon ang kuryente nyan. wag ka mag alala safe yan. wag mo lang hahawakan. at walang masisira jan. hindi mo naman paliliguan ng tubig ang distributor eh. if you found some sparks. I would suggest na wag mo nang isugal ang biyahe mo. masama ang effect ng arc sa electronic circuit ng kotse. pwdeng sirain ng arc ang computer mo or yung mga sensors sa distributor. mataas na voltahe yan eh. for precautionary measure. pwdeng hindi ka tumirik sa ngayon pero di mo masasabi kung kailan mapupundi ang elecronics mo.
