Results 1 to 3 of 3
- Sep 2013
- 55
December 19th, 2013 12:23 PM #1Lxi 97/ Honda.
Gud Am Mga master Ng drain po ako ng radiator and put NATION coolant worth 130p and add distilled water. tapos nung binibleed ko na when i REV the car nag overflow po then lumabas po un brown foam sa radiator ko. ginamit ko po un car ok na nman un coolant hinde nag babawas sa radiator wala rin sign na ng mix un water sa oil when i checked the dipstick, oil cap at hinde rin mausok un radiator ko bago 2 rows.kinabukasan drain ko ulit un coolant sa radiator kase kinabahn po kase ako and put distilled water only after nun nabwasan na un brown foam ano po cause nito?first time ko lng mag lagay ng coolant after ng top overhaul salamt mga master.
- Oct 2009
- 2,271
December 20th, 2013 09:07 PM #2ako din after na maglagay ako ng coolant may parang brown na lupa sa takip ng radiator ko..sabi nila normal lang daw ung ganon mga dumi lang daw un na tinatanggal ni coolant sa makina..
at kapag nakayod na lahat ni coolant ..sa 2nd time na maglagay ulit ng coolant ay mawawala na din un..
- Sep 2013
- 55
December 30th, 2013 08:27 AM #3
agree... but I don't think its the "T" Badge. kasi the Livina at 1.2M is basically the old...
All New Toyota Corolla Cross
