Results 11 to 20 of 20
- Jun 2005
- 155
October 27th, 2009 03:03 PM #11
Tsikot Member Rank 4
- 2,716
- Aug 2009
- 109
October 27th, 2009 03:15 PM #13
- Jun 2005
- 155
October 27th, 2009 03:19 PM #14patay! hehe . walang circular motion yung tubig sa radiator pag ni rev? at lumalabas?..puedeng madumi radiator or sa makina.
- Jun 2005
- 155
October 27th, 2009 03:23 PM #15Palitan mo ang cap sir and have the radiator cleaned.Yan muna gawin mo.Pag overheat pa rin sa makina na yan
- Aug 2009
- 109
October 28th, 2009 02:31 PM #16may leak pala ung rad ko mga sir..pero nakakatulong naman ung pagrekta ko ng fan para di madaling maubos ung coolant.
guys tanong ko lang kung magkano bagong rad? kasi ang sabi sakin papalitan daw nila ung top ng tanso which is 3000php labor inclusive.
big big thanks sa mga nagrereply..God bless
October 28th, 2009 03:12 PM #17
Kawawa ang motor ng fan mo at OT ang trabaho ng alternator to make-up for the extra load ng naka-rektang fan 'though it really helps in bringing down the temp . . . at least for the meantime.
Ganyan din ang ginawa sa rad ng '97 City ko, converted to brass tank yung top. Mahal kasi kapag palit ng buong rad which is plastic. Mag-canvass ka pa sa ibang shop para madagdagan ang options mo. How about checking those surplus shops in Banawe or Evangelista? I have no idea about the price of a brand new unit (you may want to inquire * [SIZE=3]Fertes[/SIZE] along Roosevelt Ave near Quezon Ave QC).
October 28th, 2009 03:57 PM #18
Kung kita mo kung saan yung leak - apply Epoxy Resin - it will hold. Just make sure dry and clean yung surface - sand it down... remove water... and allow to cure for 24 hours para maganda ang kapit.
Para maganda ang finish, when you apply epoxy resin A & B... you can mold it like clay by wetting your finger or foam.
This will save you a lot. Then put back your fan to the original wiring.
At any rate, maliit lang naman ang rated wattage consumption ng fan mo... around 3 to 5A lang kaya di naman burden sa alternator yan. However, mas maganda pa rin kung sensor activated ito.
If you buy a new Rad - it may cost about between 3 to 6K. Kung may budget ka naman... better buy a new one.
November 14th, 2009 02:23 AM #19
November 14th, 2009 02:31 AM #20
Kung sira na radiator cap pag uminit makina tatapon ang tubig na laman ng radiator imbes na mapalitan ng tubig na nasa water reservoir coolant.
