Results 1 to 5 of 5
- Aug 2011
- 2
August 15th, 2011 09:25 AM #1mga boss ano kaya prob pag lgi nmamatay ung car pag na ttrafic tpos nka start na my ilaw pdin ung ignition light, tpos nwawalan ng break prang lumulusot ung hangin? my alm po ba kau ng pagawan ng honda d2 sa my gwing baliuag po?
salamt po sa mga 22long
August 19th, 2011 08:43 PM #2
ok ba idling mo before mamatay engine? anung ilaw yung mentioned mo na iginition light?
- Oct 2008
- 944
August 20th, 2011 01:45 PM #3sa mga nae-encounter mo demonika, mukang matindi tinding ayusin gagawin mo sa accord mo ah? wag naman sana overhaul
- Dec 2006
- 234
August 21st, 2011 01:31 AM #4malamang yung Check Engine Light yang sinasabi mo.
Punta ka sa shop na may ECU scanner, para ma diagnose yung error code.
Yung sa preno, kung lumulobog bigla pedal at nawawalang ng kagat yung preno, kadalasan yung Brake Master Cylinder ang may issue, baka may leak na mga seals sa loob. Pa overhaul mo yung Master Cylinder, mura lang yun.
- Jan 2011
- 262
August 21st, 2011 08:06 PM #5It would be better to buy a brand new replacement brand brake master cylinder.
But have the mechanic check the wheel cylinders first. Sometimes it's also the reason why brakes systems are "lumulusot." Wheel
cylinders are cheaper to replace that's why it's better have it checked first.
One feature they should incorporate in EVs is speed limiting based on the keyfob you hand over to...
