Results 11 to 20 of 30
February 9th, 2010 09:17 AM #11
Oh okay. The previous owner might have used gel-type air fresheners however.
The idle speed is going up precisely because the compressor is trying to do its job. However it cannot provide any cooling due to the dirt in the lines, so it's trying to work as hard as it can - taking the engine along with it. Remember that the compressor is basically driven by a belt off the engine crankshaft.
Try to get it cleaned ASAP and see what happens. I used to recommend A/C cleaning every year, but I've tried skipping out this time. So far so good, after 1-1/2 years, but I recommend having it cleaned before summer hits (for obvious reasons)
- Dec 2006
- 35
February 9th, 2010 04:42 PM #12
- Apr 2009
- 33
February 12th, 2010 04:42 PM #13Hello Guys,
These are the possibilities when your aircon is intermittently working:
1) Cooling fan on the condenser faulty... replace or change carbon brush
2) Compressor electro magnetic clutch faulty - replace or rewind
3) expansion valve clogged - replace valve, change filter drier
4) compressor relay faulty - this happens when the compartment is hot and the relay coil fails
5) Thermo sensor faulty - this happen when your sensor probe fails and cant give feed back to the system controller the right temperature
6) system under charge - if your system is under charge (or over charge) it will cause icing on the evaporator, causing inaccurate reading
7) regularly clean your aircon system...
happy motoring
- Dec 2006
- 35
February 15th, 2010 10:34 PM #14
- Dec 2006
- 35
February 16th, 2010 11:04 PM #16
guys i have also problem with mine too..yung sa akin naman,gumagana naman yung compressor,tapos lalamig naman,after a while di ko na mafefeel yung lamig blower nalang yung nafefel ko,pinalinisan ko ganun pa rin,wala naman leak,di kaya sira na yung expansion valve o madumi na talaga yung filter drier?need help pls
February 17th, 2010 12:58 AM #17
February 20th, 2010 11:04 PM #18
Brought my car to the honda shop this morning for check-up of the AC. For the meantime, they just cleaned the electro magnetic clutch since its already dirty. Wala naman nakita ang technician na problema sa system. Okay naman ang refrigerant, at saka malinis naman daw ang mga outlet ng blower. Cooling is okay pa naman, so wala mo na binaklas...observed lang daw muna...after clean-up. Aux fan are normally operating....
sana yun na nga ang solusyon.....
- Oct 2004
- 33
March 6th, 2010 11:00 PM #19Sir medyo sa OT sa City kase yung sakin naman eh civic 97 model, lately kase pansin ko naaamoy ko yung amoy ng labas ng car, halimbawa nung mapahinto ako sa tapat ng palengke ng isda eh amoy ko yung lansa ng isda o kaya yung trak na mausok na sinusundan ko eh amoy ko ang usok, pansin ko before that sa air vent eh may lumalabas pakonti-konti na parang foam.
Mga Sir ano po kaya sira at may nakapagpagawa na ba sa inyo ng katulad ng problema ko. TIA
March 6th, 2010 11:33 PM #20
sir, saan ba naka position yung FRESH AIR/ RE-CIRCULATION LEVER ng A/C mo? Baka sa Fresh Air naka position ang lever, papasok talaga lahat na amoy sa labas. Dapat sa RECIRCULATION naka set if your on city driving. If naka set sa recirculation position at ang amoy sa labas papasok pa rin baka hindi fully closed ang ventilation kaya pumapasok pa rin ang amoy.
Burberry Men Leather Jacket oskarjacket
Verifpro - paypal, ebay, banks, crypto, docs and...
