Results 1 to 6 of 6
    Guys I really need your suggestions and opinions with my problem. May grinding sound akong naririnig sa CRV ko pag lumiliko ako either left or right at low speed lalo na kung naka full turn. Bago pa lang to na issue sa akin.
    I read in some forums na a replacement of differential oil (HONDA DUAL PUMP FLUID) will solve the problem. Others say na baka dapat na palitan Constant Velocity Joint (which im sure will cost me alot ).
    I think once pa lang napalitan ng Differential Oil yung CRV ko, it was just turned over to me by my father with a 156K+ mileage.
    Sa mga expert at CRV owners dyan pa share naman po ng experience nyo about this problem. I'll monitor closely on this thread.
    Thanks sa mga nagreply at nagbasa nito.
    Aug 2004
    If it's grinding, I'd say it was more a case of the differential than CV Joints. CV Joints are more of a 'tok tok tok tok" noise when turning.
    May 2009
    sir napa check mo ba ung rack and pinion mo? sa crv ko may grinding sound din pag nag turn ako to right and left. kasi may leak na ung rack and pinion ko, after changing the rack and pinion ok na ult crv ko..
    Sana nga sir sa differential lang at sana din yung oil lang ang problema.. matibay naman yung differential gears eh. thanks alot niky..
    Quote Originally Posted by sidney16 View Post
    nako di ko pa napa check yun sir. yikes! magkano ba na nagasto mo sa rack and pinion sir?
    mukhang mabibigatan ako nito ah..
    so far malambot naman yung steering niya sir at di naman lumiliko ng kusa sa straight roads.
    May 2009
    Quote Originally Posted by rax06 View Post
    sir nagastos ko ay 20k surplus parts.. ung luma ko na rack and pinion malambot din at tsaka di naman lumiliko magisa sa straight roads un nga lang maingay xa pag nag manuever ako or pag pipihitin ko lng ung steering wheel..
Grinding sound of 2004 Honda CRV (4WD) when turning
