Results 1 to 6 of 6
- Nov 2008
- 9
November 4th, 2011 01:15 PM #1Guys I really need your suggestions and opinions with my problem. May grinding sound akong naririnig sa CRV ko pag lumiliko ako either left or right at low speed lalo na kung naka full turn. Bago pa lang to na issue sa akin.
I read in some forums na a replacement of differential oil (HONDA DUAL PUMP FLUID) will solve the problem. Others say na baka dapat na palitan Constant Velocity Joint (which im sure will cost me alot ).
I think once pa lang napalitan ng Differential Oil yung CRV ko, it was just turned over to me by my father with a 156K+ mileage.
Sa mga expert at CRV owners dyan pa share naman po ng experience nyo about this problem. I'll monitor closely on this thread.
Thanks sa mga nagreply at nagbasa nito.
November 4th, 2011 04:38 PM #2
If it's grinding, I'd say it was more a case of the differential than CV Joints. CV Joints are more of a 'tok tok tok tok" noise when turning.
- May 2009
- 38
November 4th, 2011 05:51 PM #3sir napa check mo ba ung rack and pinion mo? sa crv ko may grinding sound din pag nag turn ako to right and left. kasi may leak na ung rack and pinion ko, after changing the rack and pinion ok na ult crv ko..
- Nov 2008
- 9
November 8th, 2011 01:15 PM #4
- Nov 2008
- 9
November 8th, 2011 01:19 PM #5
- May 2009
- 38
November 8th, 2011 11:21 PM #6
The current gen Kicks e-power is basically a compromise, as the body+chassis design came first...
2025 Nissan Kicks
