Results 1 to 3 of 3
- Nov 2010
- 5
November 19th, 2010 01:22 PM #1I have Honda Accord 1995 po. Automatic Transmission. Medyo delay po ang shifting, pero my mechanic told me it's because of block transmission filter.
November 19th, 2010 01:24 PM #2
any gas station na may service station kaya mag palit ATF.
pero try mo sa Alpha sa Marikina, may machine sila dun na hihigupin lahat ng ATF na nasa loob ng case. unlike yung drain lang, may natitira kasing luma na fluid.
November 19th, 2010 10:24 PM #3
i think all honda automatics have non-serviceable filters. the transmissions are sealed, so you can't access the filter screen inside, unlike ibang kotse.
baka kulang lang yung fluid. or baka mali yung nilagay mo nun (patay ka...). honda transmissions require atf-z1 fluid from honda lang. if you put those fluids you can buy sa gas stations it will break (not agad agad naman), guaranteed.
the triumph of man over... man!, using the crudest of implements (by modern standards).
Traffic!
