Results 11 to 17 of 17
January 5th, 2013 12:37 PM #11
I have been not using OEM for a long years now on my older CRV, both PSF and ATF...never nag leak both system...
and I just talked to a Honda SA last thursday when I had mg change oil, and asked him about this thing and her said its not true unless low grade than OEM ang gagamitin.
January 5th, 2013 02:03 PM #12
I wouldn't trust everything what the SA says. They form their own opinions and what he says: a) doesn't always reflect their company's position on the matter, and b) they're the same guys who denies warranty on cars not using OEM fluids.
Like I said, it's a hit or miss. You're lucky you didn't end up with the bunch of other guys who failed in their attempts to save some loose change.
January 5th, 2013 02:09 PM #13
But what i replaced with is more expensive than OEM, as I've said replacement should be at par or better than OEM.
January 5th, 2013 02:44 PM #14
January 5th, 2013 03:00 PM #15
Definitely, fluids of diffferent type will wreck havoc in any system. Like putting ATF on power steering system...
What I'm trying to say its ok to put non OEM fluids to Hondas as long as quality is at par or better.
Sent from my iPad using Tapatalk HD
January 5th, 2013 03:58 PM #16
Refering to ATF Type... ie. Mercon, Dexron, SP-III, ATF+4, ATF-Z1/DW1, etc. and all their subs.
Each manufacturer has specific ATF requirements. Incorrect transmission fluid may result in transmission malfunction or severe damage.
- Nov 2011
- 79
January 10th, 2014 04:53 AM #17Each manufacturer has specific ATF requirements. Incorrect transmission fluid may result in transmission malfunction or severe damage.
Keyword " may result " ...It means they are not even so sure about it
I've been using non-honda fluids for my power steering (im using petron's ATF), Brake fluid (prestone), clutch fluid (prestone), radiator coolant (coolant lang na walang brand, green color) and synthetic oil (Idemitsu, ito daw OEM ng Honda di umano). so far nothing weird had happened nor is happening...and nope, im not talking about months of usage, im talking about years (more than 2 years).
Hybrids and EV
