Results 1 to 7 of 7
- Jun 2010
- 321
February 4th, 2011 08:19 PM #1before ma repaint ang engine bay walang problema sa starting after ma repaint at ibinalik mga brake, clutch aircon lines and wires ayaw nang mag start, may redondo naman pero ayaw mag tuloy start........ pina check ko sa mechanic tinangal namin ang hi ten wire then try ground walang spark...... naka connect naman lahat ng sensor.... wala lang talagang kuryente or spark na lumalabas sa distributor ok naman main relay kasi nag cclick naman and di naman umiilaw CEL Nya.... duda ako sa nag kabit ng wires baka may nagalaw, posible kaya?......... please help sa mga engine guros dyan mis ko nang patakbuhin eg sedan ko 9 months na atang nasa motor pool panay gastos
- Jun 2010
- 258
- Jun 2010
- 321
February 7th, 2011 06:22 PM #3pina check ko na mukhang sa distributor ang sira, baka daw sira ang igniter or coil .... na rerepair ba ang distributor? san kaya pwede pagawa ito at how much kaya ang repair?
- Jun 2010
- 258
February 8th, 2011 01:25 AM #4
- Jun 2010
- 321
February 14th, 2011 07:59 PM #5update..........problem solved!!!!!!!!!! bad dizzy pinalitan ko na lang ng surplus...
follow up question magkano kaya ang oem and replacement thermo switch? salamat sa mga nag reply
- Oct 2008
- 1
February 15th, 2011 02:17 AM #6
- Jun 2010
- 321
February 15th, 2011 02:03 PM #7same problem din basa ng langis........ try mo muna linisan disassemble mo lahat ng parts ng dizzy i have the link how to pm me if you want ...di pa nga bayad basta binigay na lang sa akin kapit bahay kasi namin sa province ang katiwala doon sa ckd/sprint banawe......... kung gusto mo bili ng dizzy surplus japan look for chris meron din mura i can give you his no. 1.5k lang
One dude told me it was Li-Ion. Another dude corrected him. AFAIK the Zenix gets the Li-Ion hence...
MG4 EV Standard vs BYD Atto 3 Dynamic vs Toyota...
