Page 17 of 17 FirstFirst ... 71314151617
Results 161 to 167 of 167
    Jul 2012
    #161
    will have to think about that.. im sure matagal na hindi na linis yung skin.
    Nov 2014
    #162
    Quote Originally Posted by albertianss View Post
    marami kasing power loss sa torque converter, kaya gumamit sila ng starter clutch para sa fuel economy. 'engine misfire' yung symptom na parang ayaw umandar saglit . maraming nalilito sa jerking at misfire. common problem yung misfire sa jazz at ang cause ay coilpack or valves clearance. madalas transmission agad akala nila sira. sa banaue nasa 13k at cvt transmission kasama ang installation 2mo. warranty. pag dating naman sa coilpack nasa 4200 ang isa hitatchi ang brand ng original. yung mga local nasa 1500 pero napakadaling masira. binago na ang design ng coilpack dahil sa common issue na misfire. kya make sure mabili mu yung bagong design na OEM. try mu remove negative terminal ng battery for 15mins. then install and drive and observe.
    TAMA ito I agree na all jerking ay CVT na kagad ang verdict ng iba pero it could be misfire lang or kulang sa supply ng fuel dahil barado na dumi ng fuel filter or may water sa fuel pwede din so better check it out talaga maigi bago mag decide to replace a certain parts so be carefull during assessment nyo....ako muntik na mag palit ng transmission at fuel pump at coil packs na ang estimate ay nasa 20k petot plus so mali pala dami pa pala pwede panggalingan ng jerking, rpm fluctuation, mataas na ang rpm mo sobra pero usad pagong ang otto at parang mamamatay during sapag abante galing sa full stop.....
    #163
    My Jazz GD3 has problems when on reverse gear! When changing gears to R, a really severe and scary vibration occurs! There's even a clanking sound coming from, I guess the transmission!
    I've been doing some back reading on this post and there's seems to be a lot to do to fix this. So if anyone can help, I'd like to know what to really do first!
    -Change CVTF - done
    -Change Transmission and Engine Supports?
    -Change Start Clutch?
    -Change Flywheel?
    -Clean EGR?
    -Clean Throttle Body - done
    -Change Fuel Filter?
    -Change Fuel Pump?
    -Change CVT Assembly? - Hopefully NOT!
    Nov 2014
    #164
    Quote Originally Posted by chujosh View Post
    -Change CVTF - done
    -Change Flywheel?
    -Clean EGR?
    -Change Fuel Pump?
    Sa reverse lang ba nagkakaproblema? If not pacheck mo rin ignition coils baka napuputol kuryente kaya kinakapos sa power minsan lalo na pag reverse....dalin mo na kay Mel Cabasa para macheck maayos hirap manghula mapapagastos ka malaki pag mali ang assessment....
    -Change CVTF - done
    -Change Flywheel?
    -Clean EGR?
    -Change Fuel Pump?
    Feb 2017
    #165
    ok pasali sa thread having same problem with honda GD1 matic, jerking , shuddering from full stop , lakas ng vibration parang sliding clutch ang feel ,ano po gamot dito \
    been reading some forum ang mga nabasa ako possible sira is , change CVTF wich i already did once problem still there , pwede din daw start up clutch ?, torque converter? PCV valve ? TPS ?
    bali nagpalit na ko 8 NGK spark plugs , check coil pack ni youtube ko lang hehe 1 lang nakita ko sira , change honda CVTF 2 weeks ago
    thanks
    Oct 2015
    #166
    Quote Originally Posted by bostoncreams View Post
    thanks
    Halos ganito din yung sa 08 City ko na CVT. we end up replacing the entire CVT. Inabot ng 20k Surplus japan, labor and CVTF included na. sa QC sa may Mindanao ave namin napagawa. So far nakakapanibago kasi ang smooth na, parang bago kung humatak.
    Alagaan lang talaga yung CVT, mas ok sya kaysa normal AT na kotse.
    Jul 2016
    #167
    Quote Originally Posted by suysuy View Post
    [ame="http://www.youtube.com/watch?v=DQ05lgWHAcA"]http://www.youtube.com/watch?v=DQ05lgWHAcA[/ame]
    Wala na ata talaga itong pagasa! Since nabili namin itong sasakyan na ito wala pa isang taon ang dami nang problema! Lemon na lemon talaga ito. Dadalhin ko sa casa bukas. Sabi naman nila na baka pwede iclaim sa warranty kasi may records kasi sa kanila na matagal na ako nag kaka problema sa CVT ko. Im so disappointed kanina!!! i took this video habang nasa stop light ako. i was so shocked!
    Ang dami naming honda. pero ito talaga ang walang kwenta sa lahat. anyone would like to buy this for 50k?
    follow up lang bro, ano kotse mo ngaun? and whats your updates sa City?
Epic Failure Of My Honda City's CVT Transmission!
